Radio buttons and checkboxes
  • Thread starter Thread starter Mitch
Mitch
Is it possible to use a radio buttons state to change the checkbox values?
IE: User clicks on a radio button, the values of the checkboxes beside it
change from blank to 'something' is this possible?
Mitch
Actually I'm wondering if it's possible to just toggle visibility on those
checkboxes I could just overlap them and I think that would solve my issue.
I'll give it a try. Open to other suggestions though.
> Mitch
Yes, that's possible, but the details depend on whether you're referring to
VBA user forms or Outlook custom forms and, if the later, whether the
controls are bound or unbound.
Sue Mosher
"Mitch" <Mitch> wrote in message
news:8417A83E-73FD-4705-91C9-CC19CCA3D983@microsoft.com...
> issue.
> > values?
> > Mitch
D Re: How do i insert radio buttons in an email Outlook VBA and Custom Forms 1
ughlook Outlook 365 Notifications ("toasts") have no action buttons, only 'X'. Using Outlook 8
I Ribbon buttons grayed-out in Outlook 2013 Using Outlook 2
F Stationery with Voting buttons Using Outlook 9
P VBA create mail with attachment and voting buttons Using Outlook 6
R Custom buttons for frequently sent to reciopients, OL 2010 Using Outlook 1
R Outlook 2007 QAT buttons not saving Using Outlook 2
H enable textboxes and buttons from received email Using Outlook 1
P Voting buttons not showing Outlook VBA and Custom Forms 1
S Catch events from pre-existing buttons in Outlook 2007 Outlook VBA and Custom Forms 7
S HELP: Add logic to what Voting buttons do Outlook VBA and Custom Forms 1
S How to Create Buttons in email body / toolbar Outlook VBA and Custom Forms 3
S HELP: Create Buttons in Outlook Email body or Tool bar Outlook VBA and Custom Forms 1
K Buttons are added multiple times in New Inspector window Outlook VBA and Custom Forms 4
S inspector toolbar buttons get multiple events Outlook VBA and Custom Forms 3
G Custom Buttons Disappear Outlook VBA and Custom Forms 1
S design buttons in email body Outlook VBA and Custom Forms 1
F Possible to restore/reinstall "special" buttons on custom form? Outlook VBA and Custom Forms 1
T Multiple Toolbars being added/Multiple Buttons being added to Mail Outlook VBA and Custom Forms 5
R Validating a group of Checkboxes Outlook VBA and Custom Forms 2
J Checkboxes when selected will appear in a textbox in Outlook 2016 Outlook VBA and Custom Forms 1
Witzker Correct Format of custom Yes/No Checkboxes Outlook VBA and Custom Forms 0
M How to Import YES/NO Checkboxes? BCM (Business Contact Manager) 0
J Checkboxes in Contact Custom Form Outlook VBA and Custom Forms 1
