How to Create Buttons in email body / toolbar
  • Thread starter Thread starter sam
sam
Hi All,
Is is possible to create buttons in outlook email body?
For eg: I want to create "Accept" and "Decline" Buttons that would populate
the content from the email body into an excel sheet.
Is this possible? If yes, how do I go on with it? Please Help.
Thanks in Advance
Do you mean buttons on the Outlook Inspector used to display the message
details (as opposed to teh Explorer which lists the messages in a folder)?
Dmitry Streblechenko (MVP)
"sam" <sam> wrote in message
news:6980C1FB-5C00-4C41-9B33-40D0B16BAF01@microsoft.com...
> Hi All,
> populate
> Thanks in Advance
Thanks for helping Dmitry,
Yes, I want buttons on the email body or the tool bar.
I am trying to design a process where I will be receiving emails from lots
of people in my company and so Want to create two buttons "Accept" and
"Reject"
So, Once I click Accept: I want to send and email back to the receipend
saying "the request has been accepted"
If I click Decline: I want to send an email back to the receipent saying
"the request has been rejected" and the reason why it has been rejected.
Can this be done in outlook?
any help would be appretiated
Thanks in Advance
> > Hi All,
> > populate
> > Thanks in Advance
You would need to insert your own button to the Explorer or Inspector
toolbar (CommandBar) and then write code in the button event handler that
takes the contents of the currently selected e-mail
(Application.ActiveExplorer.Selection collection) and performs the
appropriate action on it - create new message using Application.CreateItem
or MailItem.Reply, populate its properties, display it using
MailItem.Display.
http://www.outlookcode.com/ is good place to start...
news:BE54F052-F0FC-4D93-AED5-66B142581706@microsoft.com...
> "Reject"
> Thanks in Advance
> > folder)?
> > > Hi All,
> > > populate
> >> > Thanks in Advance
S HELP: Create Buttons in Outlook Email body or Tool bar Outlook VBA and Custom Forms 1
P VBA create mail with attachment and voting buttons Using Outlook 6
T Create a group from a large To distribution list Using Outlook 3
