marking an incoming message when I am not in the 'To' or the 'Cc'
  • Thread starter Thread starter Russ
Russ
I have written a lot of VBA code in excel but not in Outlook.
I would like to mark incoming messages that I recieve with a color if I am
not in the 'To' list or the 'Cc' list (which means I got the message as a
'Bcc'). I looked over using rules but they fall just short.
russ
Do you mean mark it with a colored flag or with a colored format in the
folder view? There's no code access to setting up an autoformat for a view
that will color specific items.
What version of Outlook?
"Russ" <Russ> wrote in message
news:BBC6B3E2-0968-4966-A944-D7E2F42C8AEF@microsoft.com...
> > russ
Re: marking an incoming message when I am not in the 'To' or the '
Yes i should have been more explicit. I just want a colored flag next to the
email in the inbox list. I am running outlook 2007.
russ
> > > > russ
Put this code in the ThisOutlookSession class module. It uses the new
flagging for Outlook 2007 and will only run in Outlook 2007. It will run
when new items come into the Inbox.
Private Sub Application_NewMailEx(ByVal EntryIDCollection As String)
Dim IDs() As String
Dim oNS As Outlook.NameSpace
Dim obj As Object
Dim oMail As Outlook.MailItem
Dim i As Long
Set oNS = Application.GetNamespace("MAPI")
IDs = Split(EntryIDCollection, ",")
For i = LBound(IDs) To UBound(IDs)
Set obj = oNS.GetItemFromID(IDs(i))
If obj.Class = olMail Then
Set oMail = obj
With oMail
If ((InStr(1, .To, "Joe Foobar", vbTextCompare) = 0) _
And (InStr(1, .CC, "Joe Foobar", vbTextCompare) = 0)) Then
' can be any of the new OlMarkInterval enum members
> MarkAsTask olMarkNoDate
> FlagRequest = "Must be Bcc"
> Save
news:9A6538AB-4AF7-4A09-925E-D1B3BD34347D@microsoft.com...
> the
> > russ
Ken,
Many thanks. This is just what I was looking for.
Russ
russ
> Dim IDs() As String
> Dim obj As Object
> Dim i As Long
> Set oMail = obj
> With oMail
> .MarkAsTask olMarkNoDate
> .FlagRequest = "Must be Bcc"
> .Save
> End If
> End With
> End If
> Next
> End Sub
> > the
> > > > russ
Jay Freedman Outlook forgets "not junk" marking Using Outlook 0
Mary B Outlook 2013: Rule for copying new email to folder & marking that copy as read Using Outlook 1
E Edit incoming emails to remove a certain sentence added by the "system" Using Outlook 1
L Specific Incoming Email Address Immediately Deleted Using Outlook 2
oliv- How to distinguish whether mail is incoming or outgoing? Outlook VBA and Custom Forms 2
T Search for incoming e-mails for a specified time range Using Outlook 1
G Detect Google Drive and OneDrive links in incoming mail Outlook VBA and Custom Forms 3
T Incoming Mail Changes Fonts Using Outlook 0
R VBA to manage incoming mail Outlook VBA and Custom Forms 2
I Capture incoming emails Outlook VBA and Custom Forms 1
D VBA to edit body of incoming email and forwarding it Outlook VBA and Custom Forms 11
P Use VBA to alert if new incoming email fits criteria Outlook VBA and Custom Forms 0
A Processing Incoming E-mails with Macros Using Outlook 0
D Delete selected text from incoming emails Outlook VBA and Custom Forms 25
Danny2015 how to change incoming mail conversationtopic successfully Outlook VBA and Custom Forms 6
R IMAP & Outlook 2007: incoming messages still going to old Inbox. Using Outlook 3
A Incoming mail not downloading Using Outlook 2
G Rule starting a VB macro against incoming email Outlook VBA and Custom Forms 3
D Setup expire date for incoming mail Outlook VBA and Custom Forms 2
MattC Some fonts the wrong size in incoming emails in Outlook 2007 Using Outlook 6
Emerogork How do I set up an "Incoming mail filter" Using Outlook 12
A Gibberish Titles & Attachments @ incoming Outlook 2013 emails Using Outlook 1
K Ask about a simple script about save a incoming mail as file on local PC Outlook VBA and Custom Forms 3
J How to sort incoming email that is sent to a different address to my main one? Using Outlook 1
M Incoming invites to my imap account does not sync to outlook.com Using Outlook.com accounts in Outlook 29
S The incoming task is not valid ((when users are accepting a Task) Using Outlook 5
Commodore Unified inbox or incoming messages view Using Outlook 27
P Automatic reply on incoming messages in outlook using VBA(only Specifi person) Using Outlook 14
A Alerts on incoming emails which are not responded since 1 day Using Outlook 1
J Cannot read incoming emails Using Outlook 2
G Modify Subject line of incoming mail where I am in Cc line Using Outlook 1
J Incoming emails going to wrong sub-folder Using Outlook 4
