VBA to manage incoming mail
Riccardo Sileci
Hi, I'm new to this, and googled everything I possibly could, but was unable to find what I need.
I'm getting too many spams, so had an idea of how to minimize the problem, but have no idea if a code for this already exists or if anybody could help me build a VBA code.
The idea is to setup a rule that runs a VBA rule with the following:
IF the incoming message has "THIS PHRASE" on the subject, then
ADD the sender's address to contact list
IF not
IF the sender's address is already on the contact list, then
EXIT
IF not
Reply to message using a template (which has the "THIS PRASE" in the subject
Permanently Delete message
EXIT
END IF
The template with "THIS PHRASE" will have some sort of explanation that I've been getting too many spam and the sender needs to simply reply to the message to be added to the contact list.
Can anybody help?
on this part - don't reply, just delete. Replying will just get you on more spammers list because it validates the address. If the sender is legit (like from a company you do/did business with), unsubscribe. Otherwise, just delete.
This much can be done using straight up rules - if words in the subject, delete (or move to junk mail).
ETA: I would do this in the first rule, or at least one early rule. Move and move on... it will take a little longer for the script to run, so you want the junk gone before the script, otherwise it could slow down processing and mail will be skipped.
IF not
This is doable - I have one that will get you started - Assign Categories to Messages using Contact Category - it looks up contacts and assigns a category but you can replace that part with anything you want it to do.
'To use in a run a script rule
Sub ContactCategories(Item As MailItem)
     Dim oContact As Outlook.ContactItem
     Dim oSender 'As Outlook.AddressEntry
     Dim SenderID As String
If Item.MessageClass = "IPM.Note" Then
Set oSender = Item.Sender
Debug.Print oSender
If Not oSender Is Nothing Then
     Set oContact = oSender.GetContact
             Set oSender = Nothing
             If oContact Is Nothing Then
' create contact here
Set oContact = Application.CreateItem(olContactItem)
With oContact
.Email1Address = Item.SenderEmailAddress
.Email1DisplayName = Item.SenderName
.Email1AddressType = Item.SenderEmailType
.FullName = Item.SenderName
.Save
            Set Item = Nothing
Hi Diane. It works beautifully! Thank you so very much!!
Enviado de meu ASUS_Z00AD usando Tapatalk
Hornblower409 Mailsorter - Find a folder quickly and file the email. With recent history (Free VBA) Using Outlook 1
S Works individually with MFCMAPI but not bulk with VBA script... Outlook VBA and Custom Forms 2
