Get current open draft message body from VBA
GuyCarnegie
Outlook 2019 64-bit
How do I get the currently open draft message object body from VBA?
I want to have a button on the toolbar that parses the message that a user is writing and performs an action on it.
This should be unrelated to the user "Sending" the message. ie the user can perform this action long before the message is ready for sending.
U Moving Microsoft 365 mailboxes from a different domain to our current domain Exchange Server Administration 2
N Having Shared Calendar shift to Current day Using Outlook 0
E Conditional formatting - when current account <> received account ? Using Outlook 3
H Select Specific Account When Sending Email, Based on Current Folder Outlook VBA and Custom Forms 1
F "This action is not available in the current mode" Using Outlook 0
J Old unread emails on current date (MDaemon Server) Using Outlook 1
T Attach Current File to a new Email Using Outlook 0
K Daily task list > show tasks on the exact due date and not on the "current date" Using Outlook 1
C Outlook VBA to set current account Outlook VBA and Custom Forms 1
R Inbox search, current folder, it's in there-but not found. Using Outlook 2
sjbtax Auto Create new Task upon Current Task completion Outlook VBA and Custom Forms 28
B Outlook 2007 Save Current View,Font,Toolbar Settings Using Outlook 6
M Change default Current View on People Using Outlook 1
C Either there is no default mail client or the current mail client cannot ... Using Outlook 1
E "Current View" settings across multiple users on same Exchange 2007 account. Using Outlook 1
E Calendar Thumbnail current day background color Using Outlook 3
G How can I identify in VBA if the current window is an item or a folder? Using Outlook 3
C Hover display of DL shows original owner, not current Using Outlook 2
D Save Current email in Directory. Outlook VBA and Custom Forms 1
L create new mail item from current item Outlook VBA and Custom Forms 4
K insert text into current position of pointer in mailcompose Outlook VBA and Custom Forms 1
S Count of Contacts In Current View BCM (Business Contact Manager) 1
S VBA access current contact? BCM (Business Contact Manager) 1
S get current position in message body of mailitem Outlook VBA and Custom Forms 8
X Re: how to access current text selection Outlook VBA and Custom Forms 1
T date/time field, current year Outlook VBA and Custom Forms 2
Q Remove filter from current view - outlook 2003 Outlook VBA and Custom Forms 4
T current cursor position in the reply event Outlook VBA and Custom Forms 1
D Re: How to specify the "current entry id" to GetItemFromID? Outlook VBA and Custom Forms 1
T Re: mailItem.HTMLBody should retrieve only current text Outlook VBA and Custom Forms 1
K I built an open-source, offline OST to PST converter for Windows Using Outlook 9
S Rule on a shared mailbox only runs when my Outlook is open Using Outlook 4
