Remove filter from current view - outlook 2003
  • Thread starter Thread starter Q2hyaXMgUXVheWxl
Q
Q2hyaXMgUXVheWxl
I need to create a macro that will clear filters from the current view. I
believe that this should be achieved by manipulating the xml. I started out
with the following:
Sub clearFiltersCurrentView()
Dim strXML As String
Dim intFilterStart As Integer
Dim intFilterEnd As Integer
strXML = Application.ActiveExplorer.CurrentView.XML
intFilterStart = InStr(1, strXML, "<filter>", vbTextCompare)
intFilterEnd = InStr(1, strXML, "</filter>", vbTextCompare)
Do While (intFilterStart <> 0 Or intFilterEnd <> 0)
If (intFilterStart = 0 Or intFilterEnd = 0) Then MsgBox "error"
strXML = Left(strXML, intFilterStart - 1) & Right(strXML, Len(strXML) -
(intFilterEnd - 1) - Len("</filter>"))
Loop
Application.ActiveExplorer.CurrentView.XML = strXML
Unfortunately, even though my strXML appears valid XML it doesn't seem to
remove the filter info from the XML of the current view. I have tried various
other methods to no avail. A simple line such as:
replace(Application.ActiveExplorer.CurrentView.XML,"UK","France")
works perfectly in changing the filter keyword from UK to France. However I
can't work out how to remove the filter altogether.
I've also noticed that if I apply a filter to a view, remove it and then
examine the output of Application.ActiveExplorer.CurrentView.XML the filter
information is still there even though it is not active. It also tends to
move to a different line in the XML (although my understanding is that this
makes no difference). It's as if there's another variable in the XML that
tells the view whether to apply the filter but I can't find it.
Please help!
Removing the <filter> </filter> text will remove the filter. However, you
are not saving the view and applying it after you change it. You need to do
that to persist your changes and to make them permanent.
After you set the new View.XML you should get the View object and use its
Save(), then Apply() methods.
In Outlook 2007 you could just get the View object and use the new Filter
property set to null string before using Save() and Apply().
"Chris Quayle" <Chris Quayle> wrote in message
news:2BAC4B02-2918-47EB-883B-8F9296051334@microsoft.com...
> Hi,
> out
> with the following:
> Loop
> End Sub
> various
> I
> filter
> this
> Please help!
Ken,
Thanks for confirming that removing the filter text is the correct way. I
had removed the save/apply lines because I've found that they are not
necessary when changing other aspects of the xml. I have now added them and
my code still does not work. Code is as follows:
Dim vCurrentView As View
Set vCurrentView = Application.ActiveExplorer.CurrentView
strXML = vCurrentView.XML
Loop
If InStr(1, strXML, "<sort>desc</sort>", vbTextCompare) Then
strXML = Replace(strXML, "<sort>desc</sort>", "<sort>asc</sort>")
strXML = Replace(strXML, "<sort>asc</sort>", "<sort>desc</sort>")
Debug.Print strXML
vCurrentView.XML = strXML
vCurrentView.Save
vCurrentView.Apply
Debug.Print vCurrentView.XML
I have added the step to toggle the sorting order to be sure that strXML is
being applied and the column sorting in my outlook view is indeed inverting
every time I run it. The Debug.Print strXML output verifies that there is no
<filter> line in the new XML, however it persists in vCurrentView.XML even
after the changes are being applied. It's as if VBA will only change the XML
for XML tags that you offer a replacement for but won't delete them.
So I'm still stuck!
Chris
> > Hi,
> > out
> > with the following:
> > Loop
> > End Sub
> > various
> > I
> > filter
> > this
> > Please help!
This isn't Outlook 2007 is it?
I'm not sure this idea will work:
Get the XML, Name, ViewType and SaveOption property values. Also capture the
LockUserChanges value. Change the current view to another of the views
available in the Views collection Then go up one level to the Views
collection and delete that view. Add your view with all the properties you
saved, using the Add() function. Then drop down to the View object you got
from Add() and set the view and apply and save it.
See if that does something for you.
"Chris Quayle" <ChrisQuayle> wrote in message
news:F7854F5D-67F5-47B4-B1FD-BB786B28E5F5@microsoft.com...
> Ken,
> and
> Loop
> Else
> End If
> Debug.Print strXML
> vCurrentView.Save
> vCurrentView.Apply
> End Sub
> is
> inverting
> no
> XML
> So I'm still stuck!
> Chris
Thanks for your help. In the end I created a new view called 'Unfiltered
view' and applied strXML (with fliter text removed) to that view and loaded
it each time I want to clear fliters. Then I use a separate view 'Filtered
view' to be loaded every time I want to apply a filter and use macros to make
sure a filter never gets applied to Unfiltered.
> > Ken,
> > and
> > Loop
> > Else
> > End If
> > Debug.Print strXML
> > vCurrentView.Save
> > vCurrentView.Apply
> > End Sub
> > is
> > inverting
> > no
> > XML
> > So I'm still stuck!
> > Chris
KuldeepTech How to Remove Multiple Duplicate Outlook PST Files from My Computer? Using Outlook 1
S remove from this device ? Using Outlook 8
G Reply a selected message and remove blank space before signature Outlook 365 version 2406 64BIT Outlook VBA and Custom Forms 2
G Reply a selected message and remove blank space before signature Outlook 365 version 2406 64BIT Outlook VBA and Custom Forms 0
D Auto Remove [EXTERNAL] from Subject + ConversationTopic (WITHOUT Redemption plug-in) Outlook VBA and Custom Forms 5
Rupert Dragwater How do I remove an email ending with @gmail.com Using Outlook 4
E Edit incoming emails to remove a certain sentence added by the "system" Using Outlook 1
Rupert Dragwater How to permanently remove an email address Using Outlook 9
E Remove flag automatically Using Outlook 4
Timmon Remove just one attachment before AutoForward Outlook VBA and Custom Forms 0
Z Remove GMAIL IMAP account from Outlook 2016 Using Outlook 2
O Remove duplicates within two accounts Using Outlook 2
D How to remove a folder, option grayed out Using Outlook 4
B Remove Subject Residual Outlook VBA and Custom Forms 3
R Chancing / remove “ something ” in the subject, online archive Outlook VBA and Custom Forms 8
Morgan Fowler Remove Signature Using Outlook 1
M VBA to remove deferred delivery on a MeetingItem Outlook VBA and Custom Forms 2
J Remove extra line above signature in reply Outlook VBA and Custom Forms 5
Diane Poremsky How to Remove RSS Support from Outlook Using Outlook 0
Diane Poremsky Remove Attachments From Messages Using Outlook 0
Diane Poremsky Remove Office 2013 Update Banner Using Outlook 0
O Remove duplicate mail items Outlook VBA and Custom Forms 6
Diane Poremsky Remove a password from an Outlook *.pst File Using Outlook 3
L Fake reminder apperaring (not in calendar) - how to remove? Using Outlook 5
J Your IMAP server wants to alert you to the following: cannot remove system folder Using Outlook 3
C how to remove icons on right hand side outlook 2013 Using Outlook 2
