how to get Outlook VBA code to work on the current folder
revansx
Hi. This is my first post here. please let me know if there is a more appropriate place to ask this:
I have the following VBA code (below) that works well for any mail in the "Inbox".
I execute it manually from the VBA ThisOutlookSession environment (Alt-F11)
But I also have lots of mail in folders from mapped PST files and what I want to do is make this code so that it works on whatever the "currently selected" folder is; even if it is a sub-folder in a PST file.
Is that possible?
Here is the code:
----------------Private Sub SetInitialProperties()
Dim ns As Outlook.NameSpace
Dim fld As Outlook.MAPIFolder
Dim objUnknown As Object
Dim mail As Outlook.MailItem
Dim prop As Outlook.UserProperty
Set ns = Application.GetNamespace("MAPI")
Set fld = ns.GetDefaultFolder(olFolderInbox)
For Each objUnknown In fld.Items
If TypeOf objUnknown Is MailItem Then
... do stuff ...
Set objUnknown = Nothing
Set fld = Nothing
Set ns = Nothing
--------------------Thanks!
-Rich
I'm also looking at this post (below) as my primary approach to accessing folders that are not sub-folders of the Inbox
http://blogs.technet.com/b/heyscrip...at-isn-t-a-subfolder-of-my-outlook-inbox.aspx
so I think I have the clues I need to reference a folder in a mapped PST file... but this isn't the same as having VBA "fetch" the current folder the user is looking at.
That's what I'm curious about if it's possible.
Continued Thanks!
Holy Cow! That worked perfectly! and was so simple... how is that possible :-P
But really, Diane, thank you so much. You made my day. :cool:
Cheers!
-Rich
Z Default VBA code for extracting data from email (Outlook) to Excel? Outlook VBA and Custom Forms 1
M VBA Auto-Reply code for Two Mailboxes on one Outlook Session. Outlook VBA and Custom Forms 4
Kelli VBA code for Outlook Using Outlook 1
J VBA code can't be completely executed in outlook 2013 Using Outlook 0
P VBA Code being completely ignored by Outlook Using Outlook 7
A Accessing .pst folder in outlook using VBA Code Outlook VBA and Custom Forms 4
P 'Trusted' VBA code in Outlook 2003? Outlook VBA and Custom Forms 2
J Want to learn VBA Macros for Outlook. What book can you recommend? Outlook VBA and Custom Forms 1
