VBA code can't be completely executed in outlook 2013
jerry_tan
Outlook 2013 64 bit
I put the same code in outlook 2013 VBA editor which was executed perfectly in outlook 2010, but in outlook 2013 only execute bcc code, the exception (if) part does not work:
Private Sub Application_ItemSend(ByVal Item As Object, _
Cancel As Boolean)
Dim objRecip As Recipient
Dim strMsg As String
Dim res As Integer
Dim strBcc As String
If Item.To = "abc@abc.com" Then
' #### USER OPTIONS ####
' address for Bcc -- must be SMTP address
' or resolvable to a name in the address book
ElseIf Item.To = "efg@efg.com" Then
strBcc = "email@email.com"
Set objRecip = Item.Recipients.Add(strBcc)
objRecip.Type = olBCC
If Not objRecip.Resolve Then
strMsg = "Could not resolve the Bcc recipient. " & _
"Do you want to send the message?"
res = MsgBox(strMsg, vbYesNo + vbDefaultButton1, _
"Could Not Resolve Bcc")
If res = vbNo Then
Cancel = True
Set objRecip = Nothing
I have signed the digital certificate for this macro, the problem is that same code in outlook 2013 only bcc part works. Can anyone suggest some adjustment for this code to work in 2013?
P VBA Code being completely ignored by Outlook Using Outlook 7
D VBA Code to strip Subject Line when replying or forwarding Using Outlook 3
Z Default VBA code for extracting data from email (Outlook) to Excel? Outlook VBA and Custom Forms 1
M VBA Auto-Reply code for Two Mailboxes on one Outlook Session. Outlook VBA and Custom Forms 4
Z Protecting VBA code - anything new? Outlook VBA and Custom Forms 2
S VBA code to rename a task (flagged message) Outlook VBA and Custom Forms 1
F VBA Code to change subject Like Outlook VBA and Custom Forms 3
Diane Poremsky Pasting VBA code (and other editing) Outlook VBA and Custom Forms 4
Kelli VBA code for Outlook Using Outlook 1
S Requried a VBA Code to export Calander details to excel... Outlook VBA and Custom Forms 4
J VBA code to determine 'show' state of SearchBar Using Outlook 7
L Send E-mail with VBA code from [E-mail Distribution Group] if I have “Send as” Using Outlook 6
S Outllok 2007 VBA code to send mail automatically from drafts folder Using Outlook 1
F No Attachment Warning - VBA Code HELP Outlook VBA and Custom Forms 1
J VBA code (rules) won't work after reboot Outlook VBA and Custom Forms 2
