No Attachment Warning - VBA Code HELP
  • Thread starter Thread starter fruitchunk
F
fruitchunk
I had this code in Outlook 2003 it warned me when I sent email without
attachment if it found the word attached in the email.
It doesn't work in Outlook 2007, please help. Thanks.
Dim lngres As Long
If InStr(1, Item.Body, "attach") <> 0 Then
If Item.Attachments.Count = 0 Then
lngres = MsgBox(" Found 'Attach' in message, but no attachment found - send
anyway?", _
vbYesNo + vbDefaultButton2 + vbQuestion, "You asked me to warn you...")
If lngres = vbNo Then Cancel = True
See under Tools/Macro/Security whether VBA is allowed to be executed.
Best regards
Michael Bauer
Am Sun, 14 Mar 2010 08:07:01 -0700 schrieb fruitchunk:
> Private Sub Application_ItemSend(ByVal Item As Object, Cancel As Boolean)
> Dim lngres As Long
send
> anyway?", _
> End If
> End If
> End Sub
A Warning When Opening attachment Using Outlook 7
T Missing attachment warning Outlook VBA and Custom Forms 1
A 2nd meeting confirmation notification ending up in Deleted Items if attachment is added Using Outlook 5
A Strange Attachment Behavior Using Outlook 9
S Paperclip icon shows without attachment in email under Sent folder Using Outlook 0
Owl Export Outlook PDF Attachment as JPG? Outlook VBA and Custom Forms 4
Timmon Remove just one attachment before AutoForward Outlook VBA and Custom Forms 0
P File Picker for attachment Outlook VBA and Custom Forms 0
D Forwarding email based on the attachment file type and specific text found on the attachment file name Outlook VBA and Custom Forms 1
N File Picker for attachment Outlook VBA and Custom Forms 2
M Autoforward just attachment OR just body. Outlook VBA and Custom Forms 0
S save attachment with date & time mentioned inside the file Outlook VBA and Custom Forms 0
B Outlook 2010 Opening Mail Attachment Using Outlook 2
R Limiting length of saved attachment in VBA Outlook VBA and Custom Forms 2
P Outlook 2013 Word Share doc as Email Attachment now brings up Eudora. Using Outlook 1
geofferyh How to change the Attachment File Name? Outlook VBA and Custom Forms 1
D Autosave Attachment and Rename Outlook VBA and Custom Forms 1
N Macro for attachment saved and combine Outlook VBA and Custom Forms 1
Andrew Quirl Open attachment, manipulate without add-on program? Outlook VBA and Custom Forms 5
Commodore Attachment icon when there is no attachment Using Outlook 3
V Saving attachment from outlook in My Documents Outlook VBA and Custom Forms 14
N automatic response with an attachment based on the subject line Outlook VBA and Custom Forms 1
M Search for attachment filename Using Outlook 0
E Open olNoteItem Attachment Outlook VBA and Custom Forms 6
Vijay Reply all by attachment name Using Outlook 10
