Required VBA code to complete task when replied to
Outlook 2013 64 bit
Hello members!
When we receive a new email we have a rule which flags it for completion today. Once replied to we mark it as complete.
We need a code that would automatically do this. I've tried creating one myself however I'm not that tech-savvy.
It would also be a bonus if the replied message was automatically flagged for follow up the day after. I've tried doing this using rules however they don't want to run on sent items.
Any help or assistance would be very appreciated.
Rules won't work for this. If you want the flagged marked automatically when you click the Reply button, you'll need to use an Item_Reply event macro. That is the extent of my programming knowledge, D. or someone else will need to tell you how to do it.
Start with the macro at http://www.slipstick.com/developer/vba-sample-reply-reply-clicked/
Add this to the code after oResponse.Display
oitem.FlagRequest =olFlagComplete
You can add a flag to oResponse, but this will send the flag to the recipient. Otherwise, you need to use a second macro - I'm not sure if an itemadd or an itemsend macro might work the best. The big problem with either is identifying the message.
Add this before the oResponse.Display:
with oResponse
.MarkAsTask olMarkTomorrow
.ReminderSet = True
end with
Or, use this macro to ask if you want to flag the message - http://www.slipstick.com/developer/code-samples/set-flag-follow-up-using-vba/ - if the messages have keywords you can use an if statement to run the macro only on the messages with that keyword.
M VBA SWcript Help Required Using Outlook 1
V Why is "Value Required" checkbox greyed out for Dates? Outlook VBA and Custom Forms 2
I IMAP - are emails dynamically fetched from server as required? Using Outlook 2
J No response required when delegate arranging meeting Using Outlook 0
A Stopping the required attendee invites Using Outlook 1
K What’s required to use BCM as a collaborative CRM platform? BCM (Business Contact Manager) 1
Diane Poremsky Help required for multiple identities when switching from POP to IMAP Using Outlook 1
J Outlook Invites automatically adding 'Required Attendees' Using Outlook 1
J Required and oprtional attendees Outlook VBA and Custom Forms 2
B Compile error: Object required Outlook VBA and Custom Forms 2
