What’s required to use BCM as a collaborative CRM platform?
kgibbs
Whats required to use BCM as a collaborative CRM platform?
How does all this work:
Currently we are using Intermedia's Exchange Server.
Will this require upgrading the service to include SharePoint as well?
Will each workstation need to run a local SQL database or is this managed via SharePoint?
Re: Whats required to use BCM as a collaborative CRM platform?
No, you don't need to upgrade to SharePoint. BCM is local and doesn't use sharepoint. You'll need SQL (or SQL Express) installed and can share a database among all workstations. SQL Express will need to be installed on the client machines, BCM will take care of it at the time of installation. You can either share one of the workstations or configure the database on a separate server and share it.
V Why is "Value Required" checkbox greyed out for Dates? Outlook VBA and Custom Forms 2
I IMAP - are emails dynamically fetched from server as required? Using Outlook 2
J No response required when delegate arranging meeting Using Outlook 0
A Stopping the required attendee invites Using Outlook 1
M VBA SWcript Help Required Using Outlook 1
Diane Poremsky Help required for multiple identities when switching from POP to IMAP Using Outlook 1
J Outlook Invites automatically adding 'Required Attendees' Using Outlook 1
J Required and oprtional attendees Outlook VBA and Custom Forms 2
B Compile error: Object required Outlook VBA and Custom Forms 2
