VBA Categories unrelated to visible calendar and Visual appointment Categories
Victor Rosenberg
I see Categories in the appointment Gui.
I also see the following VBA methods, properties, and uses.
MyEvent.ShowCategoriesDialog
MyEvent.Categories (sting also set by =)
CategoryArray = Split(MyEvent.Categories, ",")
My problem is that the GUI Categories and the VBA categories are unrelated.
that is, if I set the GUI to have 1 category such as "Birthday."
MyEvent.Categories is blank.
If I then set MyEvent.Categories = "Anniversary"
MyEvent.Categories does show as "Anniversary."
But . . . the GUI still only shows Birthday"
(MyEvent.ShowCategoriesDialog relates to the VBA category, not the GUI one)
Can anyone explain this and hopefully tell me how to impact the actual category, as shown in my appointment and my calendar?
Thanks . . . Vic Rosenberg
it is not picked up in the Calander or the appointment window.
nor is the category that IS in the window visible to VBA.
They each work fine (VBA and GUI), but they are simply not the same property.
J Add categories to Shared Mailbox using VBA Using Outlook 2
Hornblower409 Outlook VBA Code Example - Unified inbox in Outlook Classic Outlook VBA and Custom Forms 0
