VBA code (rules) won't work after reboot
  • Thread starter Thread starter John66
John66
First off I am not very knowlegeable about Outook or VBA coding so I
apologize in advance for missing the obvious.
I have created some rules in outlook (actually exported/imported from a
functioning account). The rules basically:
-look for an email with an attachment and with a specific word in the
subject line
-move the email to a different folder
-copy the attachment and place it in a shared system folder (done with VBA
code)
The problem I have is the rules will only work until Outlook is closed down
or the server is rebooted. After that the rules partially work (the VBA code
doesn't). The VBA code is still visible in the editor and the rules still
point to the applicable VBA script. However, the code just doesn't run.
To get around the problem, I delete the .otm file and rebuild (via import of
the .bas files) the VBA project, save it, and close the VBA editor. Until I
close down Outlook again the rules all function properly.
Could anyone describe to me where i am going wrong.
John
Does other VBA code run? If not, check your macro security settings. You
might also put a Debug.Print statement in the Application_Startup event
handler to "wake up" the VBA environment.
Sue Mosher
"John66" <John66> wrote in message
news:4D4B6B42-9683-4F2F-A810-BB9BBD2F0512@microsoft.com...
> subject line
> code)
> down
> code
> of
> I
> Thanks,
> John
Thank you so very much for your help!
The security settings were the problem.
> > Sue Mosher
> > subject line
> > code)
> > down
> > code
> > of
> > I
> > Thanks,
> > John
D VBA Code to strip Subject Line when replying or forwarding Using Outlook 3
Z Default VBA code for extracting data from email (Outlook) to Excel? Outlook VBA and Custom Forms 1
M VBA Auto-Reply code for Two Mailboxes on one Outlook Session. Outlook VBA and Custom Forms 4
Z Protecting VBA code - anything new? Outlook VBA and Custom Forms 2
S VBA code to rename a task (flagged message) Outlook VBA and Custom Forms 1
F VBA Code to change subject Like Outlook VBA and Custom Forms 3
Diane Poremsky Pasting VBA code (and other editing) Outlook VBA and Custom Forms 4
Kelli VBA code for Outlook Using Outlook 1
S Requried a VBA Code to export Calander details to excel... Outlook VBA and Custom Forms 4
J VBA code can't be completely executed in outlook 2013 Using Outlook 0
P VBA Code being completely ignored by Outlook Using Outlook 7
J VBA code to determine 'show' state of SearchBar Using Outlook 7
L Send E-mail with VBA code from [E-mail Distribution Group] if I have “Send as” Using Outlook 6
S Outllok 2007 VBA code to send mail automatically from drafts folder Using Outlook 1
F No Attachment Warning - VBA Code HELP Outlook VBA and Custom Forms 1
N VBA code to show today's date + a sequencial number in subject lin Outlook VBA and Custom Forms 1
