VBA code to determine 'show' state of SearchBar
JackPollack
Trying to write a small VBA macro for OL2003 that always opens the SearchBar when in a contact folder. I am putting my code in the FolderSwitch event.
I am able to find the ID of the SearchBar in the menu, but cant find a property to tell if it is already showing (.visible always returns true, even if not showing). Is there a way to figure out the view state as my code is toggling the state.
Set objCBCtl = Application.ActiveExplorer.CommandBars.FindControl(ID:=5592)
objCBCtl.Execute
Also as I side question, a client asked my and I couldn't answer, when the SearchBar is showing and you type in some text why soemtimes do you have to hit enter once to start the search and other times hit it 2 or 3 times? I have had the same problem, but cant figure out if it is a focus issue or something else.
On the second question, it shouldn't work like that. I'm not sure if its a focus thing or just that the enter key is not registering. It has happened to me too.
Diane is on vacation this week and she (or someone else) will need to the other question.
I'm only half back from vacation this week. I was hoping to 4 hours of work in this morning but was lucky to get 2 hours in.
Have you seen this? To show the Find pane when you switch to a Contacts folder in Microsoft Outlook
This is supposed to work but its not working for me. I tried all variations of testing the state - <>, buttondown...
With objCBCtl
If objCBCtl.State = msoButtonUp Then
> Execute
it does work! Thanks
Private Sub OutlookApp_FolderSwitch()
Dim objCBCtl As CommandBarControl
If objCBCtl.State <> -1 Then objCBCtl.Execute
Set objCBCtl = Nothing
Set objFolder = Nothing
D VBA Code to strip Subject Line when replying or forwarding Using Outlook 3
Z Default VBA code for extracting data from email (Outlook) to Excel? Outlook VBA and Custom Forms 1
M VBA Auto-Reply code for Two Mailboxes on one Outlook Session. Outlook VBA and Custom Forms 4
Z Protecting VBA code - anything new? Outlook VBA and Custom Forms 2
S VBA code to rename a task (flagged message) Outlook VBA and Custom Forms 1
F VBA Code to change subject Like Outlook VBA and Custom Forms 3
Diane Poremsky Pasting VBA code (and other editing) Outlook VBA and Custom Forms 4
Kelli VBA code for Outlook Using Outlook 1
S Requried a VBA Code to export Calander details to excel... Outlook VBA and Custom Forms 4
J VBA code can't be completely executed in outlook 2013 Using Outlook 0
P VBA Code being completely ignored by Outlook Using Outlook 7
L Send E-mail with VBA code from [E-mail Distribution Group] if I have “Send as” Using Outlook 6
S Outllok 2007 VBA code to send mail automatically from drafts folder Using Outlook 1
F No Attachment Warning - VBA Code HELP Outlook VBA and Custom Forms 1
J VBA code (rules) won't work after reboot Outlook VBA and Custom Forms 2
