Gibberish Titles & Attachments @ incoming Outlook 2013 emails
Ami
Outlook 2013 32 bit
My outlook 2013 is converting Hebrew titles to a combination of question marks and Hebrew attachment filenames to a combination of hyphen symbols.
My laptop has English and Hebrew installed and in Options/Advanced/International Options Hebrew Windows is selected for encoding for outgoing messages (I could not find if there any setup for incoming messages). UTF-8 support for the mailto: protocol is allowed.
How can I get all my Hebrew emails in their original format?
Thank you,
Ami
Are they in Hebrew on the web server? log in to web mail and check. The default settings should be sufficient for it to work - Unicode controls it. If its Unicode and you have the font installed, it should work.
It's possible the message was messed up by a virus scanner. If you use anything except Microsoft's offering, restart outlook in safe mode and download a new message (messages already downloaded usually won't be fixed). If new messages are ok, then its an addin causing problems.
T Outlook 2007 - trouble with alphabetizing when titles are used (ie - Mr.) Using Outlook 0
G Print email attachments when hit subfolder Outlook VBA and Custom Forms 1
KurtLass Opening Graphics Attachments in Outlook 2021 Using Outlook 0
F Outlook 2016 Email with attachments not being received Using Outlook 2
Commodore PDF attachments started to open in Edge Using Outlook 0
A Attachments.Delete Outlook VBA and Custom Forms 3
shrydvd vba to secure zip attachments Outlook VBA and Custom Forms 3
R fetching blocked attachments Outlook VBA and Custom Forms 0
H Outlook 2016 sent over 30 copies of an e-mail with attachments Using Outlook 1
R Outlook is NOT removing attachments. Using Outlook 4
Dan_W Nested email attachments Outlook VBA and Custom Forms 4
S DRAGGING MAIL AND ATTACHMENTS TO CALENDAR Using Outlook 1
G Download pdf attachments only if email subject has one of words Outlook VBA and Custom Forms 8
I Forwarding attachments in email received Outlook VBA and Custom Forms 3
M Outlook 2016 msg attachments Using Outlook 0
M Macro for attachments download adjustment Outlook VBA and Custom Forms 3
Diane Poremsky Save Messages and Attachments to a New Folder Using Outlook 0
B Delete/replace old files and save new attachments Using Outlook 1
Diane Poremsky Disable Protected View for Outlook Attachments Using Outlook 0
