Voting buttons not showing
  • Thread starter Thread starter PPL
P
PPL
I'm sorry for the cross-posting:
Using Outlook 2003, I've created and published a customer satisfaction form
with voting buttons to the Organizational Forms Library.
I have one problem: the voting buttons don't appear, when the form is opened
Interestingly, if users open the form and send it to themselves, then the
voting buttons do appear?
Can anyone think of a VBA work-around please?
I'd like to be able to see the voting buttons on the form as soon as it is
opened from the Organizational Forms Library?
TIA
Phil
That's normal and by design.
Sue Mosher
> TIA
> Phil
F Stationery with Voting buttons Using Outlook 9
P VBA create mail with attachment and voting buttons Using Outlook 6
S HELP: Add logic to what Voting buttons do Outlook VBA and Custom Forms 1
M How to export Voting Results with user names and their responses Outlook VBA and Custom Forms 13
C Voting Issue with Shared Inbox Using Outlook 1
R How can I retain embedded object with voting button reply? Using Outlook 5
T Voting and auto reply Exchange Server Administration 3
H Issue with Custom Voting options Using Outlook 3
S Outlook Email Help: Select custom voting button options VBA Outlook VBA and Custom Forms 1
ughlook Outlook 365 Notifications ("toasts") have no action buttons, only 'X'. Using Outlook 8
I Ribbon buttons grayed-out in Outlook 2013 Using Outlook 2
R Custom buttons for frequently sent to reciopients, OL 2010 Using Outlook 1
R Outlook 2007 QAT buttons not saving Using Outlook 2
H enable textboxes and buttons from received email Using Outlook 1
D Re: How do i insert radio buttons in an email Outlook VBA and Custom Forms 1
S Catch events from pre-existing buttons in Outlook 2007 Outlook VBA and Custom Forms 7
S How to Create Buttons in email body / toolbar Outlook VBA and Custom Forms 3
S HELP: Create Buttons in Outlook Email body or Tool bar Outlook VBA and Custom Forms 1
K Buttons are added multiple times in New Inspector window Outlook VBA and Custom Forms 4
S inspector toolbar buttons get multiple events Outlook VBA and Custom Forms 3
G Custom Buttons Disappear Outlook VBA and Custom Forms 1
M Radio buttons and checkboxes Outlook VBA and Custom Forms 2
S design buttons in email body Outlook VBA and Custom Forms 1
F Possible to restore/reinstall "special" buttons on custom form? Outlook VBA and Custom Forms 1
T Multiple Toolbars being added/Multiple Buttons being added to Mail Outlook VBA and Custom Forms 5
J Outlook Classic on desktop suddenly showing Contacts in 'new Outlook' format Using Outlook 4
S Mail not showing in created folder Using Outlook 10
O Outlook 2024 not showing that messages are replied to or forwarded Using Outlook 3
D MS365 Subscription renewal showing different dates Using Outlook 5
T Showing Removed Attachments in Thread Outlook VBA and Custom Forms 4
D Amazon and some other emails not showing in Preview Pane Using Outlook 10
A Quick Access Toolbar Not Showing Description Using Outlook 0
U Outlook 2021 not showing contact cards in Searches Using Outlook 1
J Outlook 365 Emails showing as links and text only Using Outlook 4
M On behalf of not showing on calendar for boss Using Outlook 1
C Icons (arrows) not showing on emails forwarded or replied to Using Outlook 8
