Voting Issue with Shared Inbox
Chipper
I noticed that when using a shared inbox, only the original sender of the voting email is able to generate the voting tracker. Is there any way for all users to view the voting responses on the tracker, rather than only the original sender?
Also, if someone other than the original sender clicks on the votes, the original sender is unable to bring that vote up within the tracker. Is there a work-around for that issue as well?
Thank you very much.
H Issue with Custom Voting options Using Outlook 3
M How to export Voting Results with user names and their responses Outlook VBA and Custom Forms 13
R How can I retain embedded object with voting button reply? Using Outlook 5
F Stationery with Voting buttons Using Outlook 9
P VBA create mail with attachment and voting buttons Using Outlook 6
T Voting and auto reply Exchange Server Administration 3
P Voting buttons not showing Outlook VBA and Custom Forms 1
S Outlook Email Help: Select custom voting button options VBA Outlook VBA and Custom Forms 1
S HELP: Add logic to what Voting buttons do Outlook VBA and Custom Forms 1
T POP Sent Folder Synchronization Issue & Inbox Email Date Display Disorder Using Outlook 2
C Solving the "indexing never finishes" issue Using Outlook 8
Z Hotmail account deleted from outlook and issue with account not exist Using Outlook 0
H Outlook 365 issue getting details from embedded files, crashing routine Outlook VBA and Custom Forms 0
A Clipboard Resize Issue Using Outlook 7
D hide messege issue Using Outlook 1
B Outllok 2007 License Expired issue Using Outlook 0
M Calendar Time Zone issue Using Outlook 0
B My outlook calendar edit issue Outlook VBA and Custom Forms 0
D Unusual calendar issue Exchange Server Administration 0
D Multiple Accounts Issue Receiving Emails in 2016 Using Outlook 0
B Winmail.dat Issue Using Outlook.com accounts in Outlook 0
tswatek Issue with where Outlook saves new contacts Using Outlook 3
K Outlook with MDaemon Connectivity Issue Using Outlook 4
G .ost file corrupted / solved the issue with some posts already said, but .ost file is corrupted agai Using Outlook 2
D Resizing issue for message field Outlook VBA and Custom Forms 0
P Outlook hanging issue Using Outlook 0
K Outlook 2013 calendar issue with Outlook.com Using Outlook.com accounts in Outlook 2
J Favorites in Public Folders issue Outlook VBA and Custom Forms 0
K Insert screenshots issue Using Outlook 2
