BCM 2007 errors
David
i have a problem running bcm 2007 sp2 on vista business. the thing is that a
client has lots of big archive .pst files.
outlook 2007 works fine, but when i install bcm2007, i connect to the remote
sql 2005 and everything looks ok, but when i try to open one archive i get an
error not enough memory to do something (something like this, the error is
localized in my language sl-si)
when i deinstall bcm 2007 outlooks works fine again.
i tried to to the regedit change as written in:
http://support.microsoft.com/kb/907651
but with no success. now the client can't access the bcm database.
this guy has the same problem:
http://social.microsoft.com/Forums/...e/thread/c32a7db0-26f0-43d0-a084-6c8c7d7ab52f
please help.
Raul Thomas
Hi David
Right click on the deleted items under Business contact manager > go to
properties > auto archive > uncheck "Do not archive items in this folder"
Regards
Rahul Thomas [MSFT]
The posting is provided "AS IS" with no warranties and confers no rights.
https://blogs.msdn.com/rathomas
"David" <David> wrote in message
news:CCAD6129-CC08-460B-B8B0-59316D81DEF0@microsoft.com...
> a
> remote
> an
> please help.
David
hi, thanks for your reply, but you missed the point. :)
i can't open the business contact manager thing (in the left panel, where
all the archive***.psts and personal folders are.)
the thing is i can't open (expand) any folders or subfolders under personal
folders, or in any archive. i get always the error not enough memory.
after uninstalling bcm, everything works fine.
then i removed all the archive psts and left only the main outlook.pst (5gb)
reinstalled bcm and still can't expand any subfolder under the personal
folders.
i can open the inbox, but if i want to click on some other folders, i get
the error not enough memory again.
"Raul Thomas" wrote:
> Hi David
> > Regards
> Rahul Thomas [MSFT]
> > a
> > remote
> > an
> > please help.
martinFroewis
Hi David,
I would like to ask if you have already found a solution for our problem?
Didi you find a way to get BCM running?
Thanks for your help!
Regards,
Martin Froewis
> folders.
> > Hi David
> > > > Regards
> > Rahul Thomas [MSFT]
> > > a
> > > remote
> > > an
> > > > > please help.
david
nope,
but i uninstalled bcm, put all the archives *.pst back in outlook. and now
the client slowly creates new empty archives and tries to limit the folders
and sub folder.
but is a pain in the lower back, since noone ...not even the guys who coded
bcm, knows the max amount of folders and subfolders, or the number of
messages that causes this out of memory error.
sugarcrm/mysql all the way from now on.
"martinFroewis" wrote:
> Hi David,
> Regards,
> Martin Froewis
> > folders.
> > > Hi David
> > > > > > > Regards
> > > > Rahul Thomas [MSFT]
> > > > a
> > > > remote
> > > > an
> > > > > > > > please help.
martinFroewis
Hi david,
thanks for your reply! Our user has more than 1000 folders/subfolders in his
account, so we couldn't go this way without knowing how many folders would
work without problems.
Does anybody know if there will be a patch/workaround in the near future? Is
Microsoft still working on this issue?
"david" wrote:
> nope,
> and sub folder.
> > Hi David,
> > Regards,
> > Martin Froewis
> > > folders.
> > > > > Hi David
> > > > > > > > > > Regards
> > > > > > Rahul Thomas [MSFT]
> > > > > a
> > > > > remote
> > > > > an
> > > > > > > > > > > please help.
J No errors from BCM 2007 but can't see database BCM (Business Contact Manager) 0
M BCM 2007 Can't find SS2012Express Using Outlook 2
T OL BCM 2007 - Possible to migrate SQL Server Express 2012 ? BCM (Business Contact Manager) 2
S BCM 2007 to 2010 migration failure issue BCM (Business Contact Manager) 1
E BCM 2007 no reminder visible at client PC in workgroup BCM (Business Contact Manager) 5
U TABS MISSING OR DUPLICATED - BCM 2007 on Vista laptop BCM (Business Contact Manager) 5
J Unable to view History items in BCM 2007 shared database BCM (Business Contact Manager) 3
C BCM 2007 to 2010 Migration BCM (Business Contact Manager) 1
M Adding BCM to Outlook 2007 BCM (Business Contact Manager) 1
F Technical Specifications for 2007 BCM BCM (Business Contact Manager) 1
T BCM 2007: Accounts creation or opening fails BCM (Business Contact Manager) 1
J BCM V.2007 BCM (Business Contact Manager) 1
T BCM Crashing during search - 2007 edition BCM (Business Contact Manager) 3
H Fail to install BCM 2007 (English) on Windows 7 64 bit (Danish) BCM (Business Contact Manager) 3
A BCM 2007 restoring database BCM (Business Contact Manager) 1
V Already have Office 2007 Prof Plus, want to get BCM BCM (Business Contact Manager) 4
F Outlook 2007 BCM Exporting Files BCM (Business Contact Manager) 2
S Import Data from 2003 BCM to 2007 BCM (on Windows 7) BCM (Business Contact Manager) 1
D Connecting BCM 2007 to a shared BCM 2003 Database BCM (Business Contact Manager) 3
G bcm 2007 sub folders BCM (Business Contact Manager) 1
L How do you Recover from An Outlook 2007 & BCM Crash BCM (Business Contact Manager) 1
A Add BCM to outlook 2007 BCM (Business Contact Manager) 1
A BCM 2007 Shared Database on member Server 2008 in SBS 2008 Domain BCM (Business Contact Manager) 1
C Error when installing BCM for outlook 2007 from disk 2 BCM (Business Contact Manager) 3
B Outlook 2007 BCM will not recognize data files BCM (Business Contact Manager) 1
S BCM in Office Ultimate 2007 Won't Install on W7 Ultimate 32 BCM (Business Contact Manager) 1
D BCM 2010 and a shared BCM 2007 Database BCM (Business Contact Manager) 5
J BCM 2007 Shutting Down Outlook BCM (Business Contact Manager) 2
M cant find my BCM 2007 disc BCM (Business Contact Manager) 1
P Windows 7 / Outlook BCM 2007 Stability BCM (Business Contact Manager) 1
A What to do if BCM didn't install with 2007 Professional Trial? BCM (Business Contact Manager) 1
N Outlook 2007 w/BCM - Email issues BCM (Business Contact Manager) 5
N Email issues since installing BCM with Outlook 2007 BCM (Business Contact Manager) 1
M Outlook 2007 with BCM - Tasks being created automatically BCM (Business Contact Manager) 1
A Unresolved items, BCM 2007 with smartphone BCM (Business Contact Manager) 1
C All my projects and project tasks are gone - OL BCM 2007 BCM (Business Contact Manager) 2
J Moving BCM 2007 Database to a SQL 2005 Server BCM (Business Contact Manager) 2
D Outlook 2007 BCM - Win 7 BCM (Business Contact Manager) 1
W Recovering Data From BCM 2007 BCM (Business Contact Manager) 2
A ACT! 10.0 to BCM 2007 BCM (Business Contact Manager) 2
V Connecting BCM 2007 to SQL Server 2007 BCM (Business Contact Manager) 1
E Re:BCM failed to install in outlook 2007 due to SQL Server Express 20 BCM (Business Contact Manager) 1
B Marketing Campaign BCM 2007 – Word 2007 Merge Fails BCM (Business Contact Manager) 1
C How to configure BCM 2007 and Hosted Exchange BCM (Business Contact Manager) 4
D Networking BCM 2007 BCM (Business Contact Manager) 4
T Would you repurchase BCM 2007? BCM (Business Contact Manager) 1
