ACT! 10.0 to BCM 2007
Ann
I am interested in moving my ACT! 10.0 database to Business Contact Manager.
The conversion wizard in the trail version of BCM does not list ACT! version
10 as supported - it only supports through version 9. Any advice?
V
vasu
Hi Ann
the direct transfer between ACT! 10.0 and BCM 2007 is not yet been
initiated. However you a few options for such scenarios -- check if ACT!
10 data can be backed up in the ACT! 9.0 format and then import them on
to BCM. If not, backup the data from ACT into CSV format and then import
on to BCM.
Regards
Vasu
Thatch
There is a site http://www.act-to-bcm.com that offers services on converting
data from ACT! to BCM. All the data is transferred properly, including
drop-down menus, dates of history/notes, attachments, etc..
C mport ACT! 6.0 to BCM BCM (Business Contact Manager) 2
T RE: ACT to BCM Data Conversion BCM (Business Contact Manager) 1
K ACT!/OUTLOOK BCM CONVERSION BCM (Business Contact Manager) 2
J importing contacts, data, emails and attached files from ACT 2009 BCM (Business Contact Manager) 1
L Act to Outlook BCM (Business Contact Manager) 1
M Importing Contacts from Act 6.0 to Outlook 2007 BCM (Business Contact Manager) 3
