RE: ACT to BCM Data Conversion
Thatch
There is a site http://www.act-to-bcm.com that specializes on converting data
from ACT! to Outlook and all the dates/attachments/etc. are maintained
properly.
"Peter Dempewolff" wrote:
> Hi Sat,
> Thanks for the info and link. It would be nice if you could get this fix
> into the next service pack.
> "Sat" wrote:
> > Hi Peter,
> > There was a similar discussion:
> > ?&cr=US&guid=&sloc=en-us&dg=microso...deb8&mid=142514fa-5717-4039-ba00-894a4dfddeb8
> > This feasibility of this issue will be discussed in future versions. Thank
> > you for the suggestion.
> > -Sat [MSFT]
> > > I think you would get a lot more ACT users to convert to BCM 2007 if you fix
> > > the date conversion so that notes, histories convert with their original
> > > creation date rather than the tranfer date as it does now. A number of us ACT
> > > users have years of important history that is only useful if it is converted
> > > with the original creation date. I am aware that you can pay to have the data
> > > converted correctly, but that little give me of having the data conversion
> > > wizard do it might be the tipping point for some more Office 2007 sales. I am
> > > in that category.
> > > > Thanks,
> > > Peter
> > > > --------------> > > This post is a suggestion for Microsoft, and Microsoft responds to the
> > > suggestions with the most votes. To vote for this suggestion, click the "I
> > > Agree" button in the message pane. If you do not see the button, follow this
> > > link to open the suggestion in the Microsoft Web-based Newsreader and then
> > > click "I Agree" in the message pane.
> > > > ?mid=ec84c5d3-3195-41fa-9521-04afd2b990be&dg=microsoft.public.outlook.bcm
Dempewolff
Thanks for the reply. I am familiar with that site. As I recall there was
various options and most of them require more money than I was willing to
pay. I decided to bite the bullet and not worry about the notes/date; I
transferred all of my data to Outlook. I miss some of the functionality; I do
not miss having to upgrade every year due to compatibility with ACT and ACT
for Palm program. I don't know if they (ACT) do it now, but before they would
upgrage the main program but it would not be compatible with the previous
versions of ACT for Palm; then they would upgrade that program and with in a
few months they would come out with a new version of the main program that
was not compatible with previous versions of ACT for Palm... frustrating. Now
I sync Outlook with my smartphone and for the most part everything is OK. -
Peter
> properly.
> T
> > Hi Sat,
> > "Sat" wrote:
> > > Hi Peter,
> > > > -Sat [MSFT]
> > > > in that category.
> > > > > > Thanks,
> > > > Peter
> > > > > > --------------> > > > This post is a suggestion for Microsoft, and Microsoft responds to the
C mport ACT! 6.0 to BCM BCM (Business Contact Manager) 2
A ACT! 10.0 to BCM 2007 BCM (Business Contact Manager) 2
K ACT!/OUTLOOK BCM CONVERSION BCM (Business Contact Manager) 2
J importing contacts, data, emails and attached files from ACT 2009 BCM (Business Contact Manager) 1
L Act to Outlook BCM (Business Contact Manager) 1
M Importing Contacts from Act 6.0 to Outlook 2007 BCM (Business Contact Manager) 3
