mport ACT! 6.0 to BCM
C
Carol B.
I have had no luck at all importing csv files from ACT! 6.0 to BCM 2007.
None, zero, zip. Whaaat? Any feedback? I see posts here are older, 2007
and older. Is anyone doing this successfully, or have they given up on
Outlook BCM?
Carol B.
Raul Thomas
Can you try using the import /export option select Business contact manager
and then see if it bring in any data
Regards
Rahul Thomas
MSFT
"Carol B." <CarolB> wrote in message
news:6E2A2ECF-D2FD-439D-872B-66D3317B3F01@microsoft.com...
> Outlook BCM?
> > Carol B.
L
Leonid S. Knyshov // SBS Expert
I seem to recall there was a product for this.
Do you just want to pull your contact data out of Act? It's the notes that
were hard to export. Getting basic data is pretty easy.
Leonid S. Knyshov
Crashproof Solutions
510-282-1008
Twitter: @wiseleo
http://crashproofsolutions.com
Microsoft Small Business Specialist
Please vote "helpful" if I helped you :)
> Outlook BCM?
> > Carol B.
J importing contacts, data, emails and attached files from ACT 2009 BCM (Business Contact Manager) 1
L Act to Outlook BCM (Business Contact Manager) 1
T RE: ACT to BCM Data Conversion BCM (Business Contact Manager) 1
A ACT! 10.0 to BCM 2007 BCM (Business Contact Manager) 2
K ACT!/OUTLOOK BCM CONVERSION BCM (Business Contact Manager) 2
M Importing Contacts from Act 6.0 to Outlook 2007 BCM (Business Contact Manager) 3
