Code not moving through messages
  • Thread starter Thread starter PJFry
P
PJFry
The code below archives my messages into a local folder. What I want to do
is to have each message stamped with an 'Archived' noted so I know it has
already been done and have the code skip that message.
The problem I am having is that the 'Archived to" string is only inserted
into the message body that I have selected when I exectute the code. If I
have no messages select, none of them are altered.
The messages save ok, but what am I missing that keeps the itm.Body from
being updated?
Sub SaveMessages()
Dim OL As Application
Dim NmeSpace As NameSpace
Dim SubTxt As String
Set OL = CreateObject("Outlook.Application")
Set NmeSpace = OL.GetNamespace("MAPI")
Set Inbx = NmeSpace.GetDefaultFolder(olFolderInbox)
Set fldr = Application.ActiveExplorer.CurrentFolder
DirName = "C:\Documents and Settings\PJFry\Email\"
For Each itm In fldr.Items
SubTxt = itm.Subject
SubTxt = Replace(SubTxt, "_", "")
SubTxt = Replace(SubTxt, "´", "'")
SubTxt = Replace(SubTxt, "`", "'")
SubTxt = Replace(SubTxt, "{", "(")
SubTxt = Replace(SubTxt, "[", "(")
SubTxt = Replace(SubTxt, "]", ")")
SubTxt = Replace(SubTxt, "}", ")")
SubTxt = Replace(SubTxt, "/", "-")
SubTxt = Replace(SubTxt, "\", "-")
SubTxt = Replace(SubTxt, ":", "")
SubTxt = Replace(SubTxt, ",", "")
'Cut out invalid signs.
SubTxt = Replace(SubTxt, "*", "'")
SubTxt = Replace(SubTxt, "?", "")
SubTxt = Replace(SubTxt, """", "'")
SubTxt = Replace(SubTxt, "<", "")
SubTxt = Replace(SubTxt, ">", "")
SubTxt = Replace(SubTxt, "|", "")
FNme = DirName & Trim(SubTxt) & " " & Format(itm.ReceivedTime,
"yy.mm.dd") & " " & itm.SenderName & ".msg"
If itm.Class = olMail Then
If InStr(1, itm.Body, "Archived to") > 0 Then
'do nothing
itm.Body = itm.Body & vbCrLf & _
"Archived to " & DirName & " on " & Now()
itm.SaveAs FNme, olMSG
Next itm
If there is a better way to accomplish the same thing, I would also love to
hear it.
PJ
You never call itm.Save
Are you sure you want to modify &all* the messages in the Inbox folder
convertign them to plain text in the mean time?
Why not use Application.ActiveExplorer.Selection collection to give the user
more control over which messages get modified?
Dmitry Streblechenko (MVP)
"PJFry" <PJFry> wrote in message
news:10CC524F-8F98-44E4-8C10-E02A54D7A0E1@microsoft.com...
> do
> being updated?
> Sub SaveMessages()
> 'do nothing
> Else
> End If
> End If
> Next itm
> End Sub
> to
> hear it.
> Thanks!
> PJ
You're not saving the item after you change the Body. You're only saving the
archived copy.
FWIW, I see nothing in the code you posted that deals with selected items.
Sue Mosher
> do
> being updated?
> Sub SaveMessages()
> 'do nothing
> Else
> End If
> End If
> Next itm
> End Sub
> to
> hear it.
> Thanks!
> PJ
Dr. Demento Analogous Outlook code to read info into an array (or collection or whatever) Outlook VBA and Custom Forms 7
P How to get a QR code for automatic signin with Outlook for iOS Using Outlook 5
H Preventing the 'email address fetch from Exchange' crashing email reading code Exchange Server Administration 0
Alex Cotton "invalid or unqualified reference" on code that should work Outlook VBA and Custom Forms 5
D Command Button code will not execute. Any suggestions Please. Outlook VBA and Custom Forms 2
C Color Code New Calendar Items Using Outlook 2
