Need code to allow defined starting folder and selection from there to drill down
ssPatriots
Outlook 365 64 bit
I'm new to this forum. I came here because I found Diane Poremsky's code called "SaveMessagesAndAttachments" and need to see if it can be tweaked to allow me to start with a defined file path and once the dialog box opens, give me the opportunity to drill down a couple folders form there to place all the files that are created. Ideally, I would like to have the Outlook "msg" file saved as a "pdf" in stead of "msg". I realize this is a lot, but I've been tinkering with the code since Friday and keep coming up empty. Thanks in advance for any help I can get on this.
Cross posted in this forum, because I didn't know this forum existed at the time.
Public Sub SaveMessagesAndAttachments()
Dim objMsg As Outlook.MailItem 'Object
Dim objAttachments As Outlook.Attachments
Dim i As Long
Dim lngCount As Long
Dim StrFile As String
Dim StrName As String
Dim strTime 'As String
Dim StrFolderPath As String
Dim FSO As Object
Dim oldName
Set FSO = CreateObject("Scripting.FileSystemObject")
Set objOL = Outlook.Application
Set objMsg = objOL.ActiveExplorer.Selection.Item(1)
' remove illegal characters and shorten name
StrName = StripIllegalChar(objMsg.Subject)
StrName = Left(StrName, 40)
strTime = DateValue(objMsg.ReceivedTime) '& TimeValue(objMsg.ReceivedTime)
' I use this to reduce changes of duplicate names
strTime = Format(objMsg.ReceivedTime, "-hhmmss")
Debug.Print strTime
strFolderpath = CreateObject("WScript.Shell").SpecialFolders(16)
Debug.Print strFolderpath
StrFolderPath = StrFolderPath & "\Attachments\" & StrName & strTime & "\"
' create folder if doesn't exist
If Not FSO.FolderExists(StrFolderPath) Then
FSO.CreateFolder (StrFolderPath)
' Save message and as html and doc file type
objMsg.SaveAs StrFolderPath & StrName & ".msg", olMsg
objMsg.SaveAs StrFolderPath & StrName & ".doc", olRTF
objMsg.SaveAs StrFolderPath & StrName & ".htm", olHTML
'save any attachments also
Set objAttachments = objMsg.Attachments
lngCount = objAttachments.Count
If lngCount > 0 Then
For i = lngCount To 1 Step -1
StrFile = objAttachments.Item(i).FileName
Debug.Print StrFile
StrFile = StrFolderPath & StrFile
objAttachments.Item(i).SaveAsFile StrFile
Next i
ExitSub:
Set objAttachments = Nothing
Set objMsg = Nothing
Set objSelection = Nothing
Set objOL = Nothing
You need to use a folder picker if you want to browse. I have a sample here - you can browse down from the starting folder but not browse up.
saving as pdf is possible -
Wow, you are genius at this!!! I also took the second code "Save Outlook as a PDF" and inserted your bit about using the "StrFolderPath" in lieu of "MyDocs" and add the "Dim StrFolderPath As String" and it worked like a charm. I putting it in this reply below. Again, thank you so much. I think I will set this up to run the "Save Outlook as a PDF" first and offer a Yes/No message box to give the user the option to save their attachments.
Sub SaveMessageAsPDF()
Dim Selection As Selection
Dim obj As Object
Dim Item As MailItem
Dim wrdApp As Word.Application
Dim wrdDoc As Word.Document
Set wrdApp = CreateObject("Word.Application")
Set Selection = Application.ActiveExplorer.Selection
For Each obj In Selection
Set Item = obj
Dim FSO As Object, TmpFolder As Object
Dim sName As String
Set tmpFileName = FSO.GetSpecialFolder(2)
sName = Item.Subject
tmpFileName = tmpFileName & "\" & sName & ".mht"
Item.SaveAs tmpFileName, olMHTML
Set wrdDoc = wrdApp.Documents.Open(Filename:=tmpFileName, Visible:=True)
Dim WshShell As Object
Dim SpecialPath As String
Dim strToSaveAs As String
Set WshShell = CreateObject("WScript.Shell")
MyDocs = WshShell.SpecialFolders(16)
' Get the BrowseForFolder function How to use Windows File Paths in a Macro
StrFolderPath = BrowseForFolder("D:\My Stuff\Email Attachments\")
strToSaveAs = StrFolderPath & "\" & sName & ".pdf"
' check for duplicate filenames
' if matched, add the current time to the file name
If FSO.FileExists(strToSaveAs) Then
sName = sName & Format(Now, "hhmmss")
strToSaveAs = MyDocs & "\" & sName & ".pdf"
wrdApp.ActiveDocument.ExportAsFixedFormat OutputFileName:= _
strToSaveAs, ExportFormat:=wdExportFormatPDF, _
OpenAfterExport:=False, OptimizeFor:=wdExportOptimizeForPrint, _
Range:=wdExportAllDocument, From:=0, To:=0, Item:= _
wdExportDocumentContent, IncludeDocProps:=True, KeepIRM:=True, _
CreateBookmarks:=wdExportCreateNoBookmarks, DocStructureTags:=True, _
BitmapMissingFonts:=True, UseISO19005_1:=False
Next obj
wrdDoc.Close
wrdApp.Quit
Set wrdDoc = Nothing
Set wrdApp = Nothing
Set WshShell = Nothing
Set obj = Nothing
Set Selection = Nothing
Set Item = Nothing
' This function removes invalid and other characters from file names
Private Sub ReplaceCharsForFileName(sName As String, sChr As String)
sName = Replace(sName, "<", sChr)
sName = Replace(sName, ">", sChr)
sName = Replace(sName, "&", sChr)
sName = Replace(sName, "%", sChr)
sName = Replace(sName, " ", sChr)
sName = Replace(sName, "{", sChr)
sName = Replace(sName, "[", sChr)
sName = Replace(sName, "]", sChr)
sName = Replace(sName, "}", sChr)
sName = Replace(sName, "!", sChr)
Sorry, I have one more question. You have the "check for duplicate filenames" in the "SaveMessageAsPDF" code. How would I make that work in the "SaveAttachmentstoFolder" code? I tried adding the bit below from the "SaveMessageAsPDF" code, but it doesn't seem to do anything. I even added the "Set FSO = CreateObject("Scripting.FileSystemObject")" part before the place I inserted the code to look for duplicates.
If FSO.FileExists(StrFile) Then
StrFile = StrFolderPath & "\" & StrFile & "-" & Format(Now, "hhmmss")
Do you get any error messages? if you have any error handlers - on error resume next for example, comment it out so error comes up.
It skips right over the part where it checks to see if the file exist in the folder.
StrFile = StrFolderPath & "\" & StrFile & "-" & Format(Now, "hhmmss") <------Skips this line
objAttachments.Item(i).SaveAsFile StrFile <------Skips this line as well.
Public Sub SaveAttachmentstoFolder()
Dim i As Long
Dim strPath As String
Dim strDeletedFiles As String
Dim sFileType As String
Dim sName As String
'On Error Resume Next
Set objOL = CreateObject("Outlook.Application")
' Get the BrowseForFolder function http://slipstick.me/u1a2d
StrFolderPath = BrowseForFolder("G:\Delaware\PROJECTS\")
StrFile = objAttachments.Item(i).Filename
'StrFile = StrFolderPath & "\" & StrFile
Next i
ExitSub:
Set objOL = Nothing
This part half works - the file extension needs fixed - the initial code had a bad path -
C:\Delaware\PROJECTS\C:\Delaware\PROJECTS\Package from Amazon.ics-001836
The code below fixes the path - but the extension needs fixed. I have code samples on slipstick that fix it but its past my bedtime - i;ll look at it tomorrow.
C:\Delaware\PROJECTS\Package from Amazon.ics-002034
  StrFile = StrFile & "-" & Format(Now, "hhmmss")
Debug.Print StrFile
Next i
ExitSub:
I see what you are saying about the extension and I think I even found the code you have on slipstick. I played with it for while and just made it worse, than where I started.
this should work- its the lazy way until I have a chance to do it right
strFile = Format(Now, "hhmmss") & objAttachments.Item(i).FileName
Makes sense, I can probably just put that time stamp and add a date in front of all the attachments in that case in order to sort easily by date/time. Thanks
R Need code snippet to read offline PST file Outlook VBA and Custom Forms 1
J Need replacement for iTunes to locally (USB) sync. iPhone 17 to Classic Outlook 2024 Using Outlook 4
macdotcom Outlook 365 Outlook folder export to PST archival tool - close, but need a nudge Outlook VBA and Custom Forms 2
P OT: Need website like this one, but for Excel Using Outlook 0
A Wishlist Arthur workman I need the community's assistance thank you Using Outlook 3
A from Arthur to anyone I need your expertise assistance Using Outlook.com accounts in Outlook 7
L Need to import multiple Outlook files to Office 365 Account Using Outlook 4
Horsepower Need iCloud mail only Using Outlook 1
O Don't need any add-ins at all? Using Outlook 2
A Need to view Outlook calendar in Sharepoint .. Using Outlook 2
L Accidentally merged a calendar with .ics, need to undo! Using Outlook 1
D Need Genuine Office or Outlook 2007 Using Outlook 3
G how to cancel a recurring meeting but not the organizer but all attendees need to know. Using Outlook 1
N Need a case sensitive rule Outlook VBA and Custom Forms 1
C Need rule to alert when an email has not been replied to within 24 hours Using Outlook 1
F Outbox - Multiple Emails need to be manually opened? Using Outlook 5
Miquela I need to make a calendar to share here at work with 40 other people Using Outlook 1
S Need CC: to show the original To: recip[ients Using Outlook 4
