Open Hyperlinks in an Outlook Email Message (Help with Diane's solution)
XD225
Outlook 2016 64 bit
I am trying to use Diane's solution but I am stuck.
I am trying to use your "Open a specific hyperlink" code. Can you let me know if the only thing I need to change is the .Pattern = "View this thread <(.*)>" part of the code? For example if I want to only click a link with the words "Claim Now" I would change my code to .Pattern = "Claim Now <(.*)>"?
As for the If InStr(strURL, "unsubscribe") Then GoTo NextURL section of the code, do I need to use this section to add all other links that I do not want to click on? I noticed that in the example there are 10 links but the author only seem to specify the "unsubscribe" link. For example, if I do not need to click on the link for contact information do I need to add something like If InStr(strURL, "contact-info") Then GoTo NextURL?
Here is what I have at the moment:
' 64bit office use:
'Private Declare PtrSafe Function ShellExecute _
Private Declare Function ShellExecute _
Lib "shell32.dll" Alias "ShellExecuteA" ( _
ByVal hWnd As Long, _
ByVal Operation As String, _
ByVal Filename As String, _
Optional ByVal Parameters As String, _
Optional ByVal Directory As String, _
Optional ByVal WindowStyle As Long = vbMinimizedFocus _
) As Long
Sub OpenHyperLinkMessage(Item As Outlook.MailItem) *I had to add this to make is available when creating the rule*
Dim Reg1 As RegExp
Dim M1 As MatchCollection
Dim M As Match
Dim strURL As String
Dim lSuccess As Long
Set olMail = Application.ActiveExplorer().Selection(1)
Set Reg1 = New RegExp
With Reg1
.Pattern = "Claim this Case Now <(.*)>" *This is the text of the link in the email*
.Global = True
.IgnoreCase = True
If Reg1.Test(olMail.Body) Then
Set M1 = Reg1.Execute(olMail.Body)
For Each M In M1
strURL = M.SubMatches(0)
Debug.Print strURL
If InStr(strURL, "referral-preference") Then GoTo NextURL *I do not know if I even need to add this or not to skip a specific link*
If Right(strURL, 1) = ">" Then strURL = Left(strURL, Len(strURL) - 1)
lSuccess = ShellExecute(0, "Open", strURL)
NextURL:
Set Reg1 = Nothing
Please advise.
That should be the only thing you need to change.
You don't need the other links listed to skip - unsubscribe is listed because the macro "clicks" the link and could unsubscribe you if the links are in a bulk mail.
I am having the same issue. The button itself in the email is labeled ACCEPT and nothing works to isolate the url. Additionally once i get the new tab opened I would like to be able to interact with the form shown using VBA. Literally is just a radio button selection them submit.
Look at the message source - copy and paste it into a text file and attach it - I'll take a look at it.
N Unable to Open Hyperlinks in Outlook 2010 Using Outlook 3
chummy Open multiple Hyperlinks to download files Outlook VBA and Custom Forms 3
Jaegel Email Hyperlinks from one source won't open Using Outlook 4
Diane Poremsky Open All Hyperlinks in a Email Message Using Outlook 0
K I built an open-source, offline OST to PST converter for Windows Using Outlook 8
S Rule on a shared mailbox only runs when my Outlook is open Using Outlook 4
K Outlook font corrupted in some point sizes, resets on close/open Using Outlook 2
T Cannot open .pst file Using Outlook 2
H Finding text in open email Outlook VBA and Custom Forms 12
Rupert Dragwater How to get Outlook 365 to open from websites Using Outlook 5
Witzker Outlook 2019 Edit contact from email does not open the user defined contactform Using Outlook 3
S Leaving ActiveExplorer open for editing after Sub is done Outlook VBA and Custom Forms 0
Commodore PDF attachments started to open in Edge Using Outlook 0
O Outlook on Android: after sharing / sending a news article, draft remains open. Why? Using Outlook 1
K Embedded photos no longer open with Photos or Photo Viewer Using Outlook 7
Witzker Open Contact missing in Outlook 2019 Using Outlook 2
sahameed82 SharePoint calendar directly open in Outlook Using Outlook 0
C Outlook 2016/2019 hangs after being open for an extended period Using Outlook 4
C Can't Open Outlook 365 Using Outlook 0
D after delete mail, open the next one Outlook VBA and Custom Forms 0
M outlook won't open! Using Outlook 1
M other user's mailbox won't open, forms disappeared Using Outlook 42
D Add Tetxbox at form open Outlook VBA and Custom Forms 1
U Catching ModuleSwitch events after "open in new window" Outlook VBA and Custom Forms 2
Andrew Quirl Open attachment, manipulate without add-on program? Outlook VBA and Custom Forms 5
S Reminder Dialog Open Button Using Outlook 2
A How to open a specific link automatically with outlook Outlook VBA and Custom Forms 13
