Color code certain INBOX emails
Friedrice
How to set rules to color code certain INBOX emails? I looked at Rules but didn't see any selection opportunity for color coding certain emails? if not using RULES, then what? Thanks
Steeferd
Outlook 2019 64-bit
  1. Navigate to View > View Settings > Conditional Formatting.
  2. In the Conditional Formatting dialog box, click Add.
  3. Type a name for your rule in the Name: field, and then click Condition.
  4. Use the fields available to you in the Filter dialog box to configure your rule's conditions.
  5. encrypted email
  6. Click OK.
C Color Code New Calendar Items Using Outlook 2
M Calendar draft notice - automatically color code? Using Outlook 1
R Setting font and color used when replying to an email Outlook VBA and Custom Forms 3
Mark Foley Color Categories on IMAP mail lost when installing new Windows 7 workstation Using Outlook 12
M Emails sorted by conversation including replies and categorized by color. Using Outlook 1
J Automatic color category according to variable domains Outlook VBA and Custom Forms 4
S Mark as Unread unless Categorized by Color Using Outlook 0
Diane Poremsky Category Color doesn't Display in Inbox Using Outlook 0
E Outlook 2016 Default Blue Color Using Outlook 3
Diane Poremsky How to Upgrade to Color Categories Using Outlook 0
J Color Alignment on the Calendar? Using Outlook 2
Simon How does the sender/organizer to dictate the color of a meeting invitation. Using Outlook 3
B Sub Calendar-Color Coding Issue Using Outlook 4
D Calendar - color coded items are now the same color Using Outlook 2
B Color Categorizing 365 Using Outlook 8
J Change Default View - Color and font Using Outlook 3
Tom.Schaefer Color for Mail-folder in OL2013 Using Outlook 1
K Color Categories for Accounts and Contacts BCM (Business Contact Manager) 0
M Background Color? Using Outlook 1
C Sync color categories on a Public Calendar across Office 365, PCs, Macs Using Outlook 1
D Background color for an entire day in Outlook 2010 Using Outlook 1
Commodore Color options in 2010... Using Outlook 0
U Color coded contacts Using Outlook 4
T Setting Color codes for each user of a shared Calendar Using Outlook 1
P Changing all email signatures (font, color) at once in outlook 2007 Using Outlook 2
M Assigning a specific font color to new emails using rules when they arrive Using Outlook 3
L Background Color Is An Issue Using Outlook 3
L Color Using Outlook 49
J Color categories with shared mailbox Using Outlook 1
F Color Coding Emails - Outlook 2007 SP-3 Using Outlook 1
C Apply Category Color for Appointment Background Color Using Outlook 2
N Changing background color on replies and forwards Using Outlook 1
E Calendar Thumbnail current day background color Using Outlook 3
M How do you change the obnoxious color of the email headers on Outlook 2013? Using Outlook 2
B Need help adding a background color to the compact list items in Month view. Using Outlook 1
J Text color when creating a new Task is not consistent Using Outlook 1
S Color catagories Using Outlook 1
