Color categories with shared mailbox
Jirelle
My manager and I share his mailbox and I would like to color categorize his e-mails (red=urgent etc), only he doesn't see the colors that I categorize the e-mails with (and vice versa). What can I do to make sure that he does see the colors on the e-mails?
Thank you in advance.
If you both have the same categories in the profile, he should see them. Categories are per user, so you need to add his categories to the shared folder on your system and the categories you are using for his mail need to be set up in his profile.
Mark Foley Color Categories on IMAP mail lost when installing new Windows 7 workstation Using Outlook 12
Diane Poremsky How to Upgrade to Color Categories Using Outlook 0
K Color Categories for Accounts and Contacts BCM (Business Contact Manager) 0
C Sync color categories on a Public Calendar across Office 365, PCs, Macs Using Outlook 1
S Missing Color Categories Outlook 2007/2010 Using Outlook 2
A Color categories Using Outlook 13
T How to get an EVENT COLOR option in Outlook 2021 ? Using Outlook 0
R Setting font and color used when replying to an email Outlook VBA and Custom Forms 3
M Emails sorted by conversation including replies and categorized by color. Using Outlook 1
J Automatic color category according to variable domains Outlook VBA and Custom Forms 4
C Color Code New Calendar Items Using Outlook 2
S Mark as Unread unless Categorized by Color Using Outlook 0
Diane Poremsky Category Color doesn't Display in Inbox Using Outlook 0
E Outlook 2016 Default Blue Color Using Outlook 3
J Color Alignment on the Calendar? Using Outlook 2
Simon How does the sender/organizer to dictate the color of a meeting invitation. Using Outlook 3
B Sub Calendar-Color Coding Issue Using Outlook 4
D Calendar - color coded items are now the same color Using Outlook 2
B Color Categorizing 365 Using Outlook 8
J Change Default View - Color and font Using Outlook 3
Tom.Schaefer Color for Mail-folder in OL2013 Using Outlook 1
M Background Color? Using Outlook 1
D Background color for an entire day in Outlook 2010 Using Outlook 1
Commodore Color options in 2010... Using Outlook 0
U Color coded contacts Using Outlook 4
T Setting Color codes for each user of a shared Calendar Using Outlook 1
P Changing all email signatures (font, color) at once in outlook 2007 Using Outlook 2
M Assigning a specific font color to new emails using rules when they arrive Using Outlook 3
L Background Color Is An Issue Using Outlook 3
L Color Using Outlook 49
F Color Coding Emails - Outlook 2007 SP-3 Using Outlook 1
C Apply Category Color for Appointment Background Color Using Outlook 2
N Changing background color on replies and forwards Using Outlook 1
E Calendar Thumbnail current day background color Using Outlook 3
M How do you change the obnoxious color of the email headers on Outlook 2013? Using Outlook 2
B Need help adding a background color to the compact list items in Month view. Using Outlook 1
