Background Color?
Mike Justis
Outlook 2013 64 bit
I am using Outlook 2013 and the 3 default colors are making my "eyes bleed". I have seen this talked about a lot but no movement on solving it. I have changed fonts and borders but softer background color would be so nice. I loved the 2010 Black color scheme...
Unfortunately, the only solution at this time is to turn down the monitor brightness - they haven't (and probably won't) release any updated themes. I found about 20% was enough to make it better - my monitors are always way too bright anyway and I usually turn them down about 10% (and use flux to adjust the color as the day progresses).
D Background color for an entire day in Outlook 2010 Using Outlook 1
L Background Color Is An Issue Using Outlook 3
C Apply Category Color for Appointment Background Color Using Outlook 2
N Changing background color on replies and forwards Using Outlook 1
E Calendar Thumbnail current day background color Using Outlook 3
B Need help adding a background color to the compact list items in Month view. Using Outlook 1
B OL 2003: UI background color anomolies Using Outlook.com accounts in Outlook 0
S Calendar background color Using Outlook 10
Rupert Dragwater Background colors not saving in Outlook 365 Using Outlook 15
J Outlook Office 365 Win 10 how do I control background colors of events? Using Outlook 1
A Outlook 2013 - VBA - Cahnging background colour Outlook VBA and Custom Forms 4
W Meeting printing background fields Using Outlook 0
D Messages received from only one sender arrive with dark gray text background Using Outlook 1
S Reminders don't pop up and stay hidden in background Using Outlook 7
R Scanning E-mail for Certain words & changing the background Outlook VBA and Custom Forms 3
J Adding a background image to a mail item using automation Outlook VBA and Custom Forms 2
R Setting font and color used when replying to an email Outlook VBA and Custom Forms 3
Mark Foley Color Categories on IMAP mail lost when installing new Windows 7 workstation Using Outlook 12
M Emails sorted by conversation including replies and categorized by color. Using Outlook 1
J Automatic color category according to variable domains Outlook VBA and Custom Forms 4
C Color Code New Calendar Items Using Outlook 2
S Mark as Unread unless Categorized by Color Using Outlook 0
Diane Poremsky Category Color doesn't Display in Inbox Using Outlook 0
E Outlook 2016 Default Blue Color Using Outlook 3
Diane Poremsky How to Upgrade to Color Categories Using Outlook 0
J Color Alignment on the Calendar? Using Outlook 2
Simon How does the sender/organizer to dictate the color of a meeting invitation. Using Outlook 3
B Sub Calendar-Color Coding Issue Using Outlook 4
D Calendar - color coded items are now the same color Using Outlook 2
B Color Categorizing 365 Using Outlook 8
J Change Default View - Color and font Using Outlook 3
Tom.Schaefer Color for Mail-folder in OL2013 Using Outlook 1
K Color Categories for Accounts and Contacts BCM (Business Contact Manager) 0
C Sync color categories on a Public Calendar across Office 365, PCs, Macs Using Outlook 1
Commodore Color options in 2010... Using Outlook 0
U Color coded contacts Using Outlook 4
