Controls in VBA
Alberto
Hello, i'd like to make more smart my controls in my VBA project. Instead of
Windows Forms 2.0 which ist the primary option when using Windows Forms I am
trying to use the controls of Microsoft Windows Common Controls 6.0 (SP6).
In particular: ListView, ListviewControl, ImageList, ImageCombo... and I'm
experiencing problems when using these controls. I´d like to show a list of
mails and an special icon associated depending of the sender. This ist not
possible with Windows Forms 2.0 and that's why i'm exploring this option.
Is it maybe not recommend the use of these controls in a VBA project??
K
Ken Slovak - [MVP - Outlook]
What problems are you experiencing, please be specific.
What version of Outlook and what version of Windows?
Where are you trying to use those controls, in an Outlook custom form or a
VBA UserForm?
"Alberto" <Alberto> wrote in message
news:038DAC3A-1282-4D59-AB06-19B65C846564@microsoft.com...
> of
> am
> (SP6).
> of
> Thank you.
Alberto
So i'm using:
Outlook 2003 11.8217 (SP3).
Windows XP Professional (SP2)
I'm trying to use these forms in an VBA UserForm.
Basically the problem appears in design mode when trying to link an
ImageList to a control which could use symbols or icons, i.e. Toolbar
Control, ListView...
I add one or more pictures to the ImageList Control, that's no problem. The
problem comes when i go to the Toolbar Control, click on (custom) and the
property pages will show. On the General tab I select Imagelist but there's
anything else than <None>. I was expecting to see the previously fullfilled
ImageList1 as selectable but it's not there, so I cannot add pictures to the
project (i didn't really go further because adding pictures is the only thing
i'm at this point interested on)
So, i would be very very happy if it was possible to use properly these
controls in VBA Forms..
Any help?
Thank you in advance...
> VBA UserForm?
> > of
> > am
> > (SP6).
> > of
> > Thank you.
K
It's very hit or miss, some of the VB6 controls work OK in UserForms, others
not so much. For example a DTPicker is OK, the image controls and image
lists don't seem compatible.
I'd probably do the coding in VB as a COM addin, then all those common
controls would work correctly.
news:62744C03-F20D-4732-B668-76B3EA5BA37F@microsoft.com...
> So i'm using:
> The
> there's
> fullfilled
> the
> thing
> Any help?
Alberto
Thanks Ken,
Writting an adding will be the next stage. At the moment I'll try to
survive within this environmment.
> > So i'm using:
> > The
> > there's
> > fullfilled
> > the
> > thing
> > Any help?
GregS What controls content of Folder Pane? Using Outlook 1
H What Controls what is shown in the preview pane Outlook VBA and Custom Forms 1
C Printing Outlook Form Controls via Word Using Outlook 11
B Adding controls programmatically Using Outlook 1
E VSTO 2008 how to bind Form Region controls to Item data fields Outlook VBA and Custom Forms 2
E VSTO 2008 how to bind Form Region controls to Item data fields Outlook VBA and Custom Forms 3
A Command Button Controls Outlook VBA and Custom Forms 6
M Adding controls in the Email Form Outlook VBA and Custom Forms 1
O Integration with 3rd-party controls Outlook VBA and Custom Forms 2
T How to delete the controls in a CommandBarPopup? Outlook VBA and Custom Forms 1
N Junk Mail Controls Outlook VBA and Custom Forms 1
G Custom controls not functioning? Outlook VBA and Custom Forms 1
C Controls in message body Outlook VBA and Custom Forms 1
P New outlook controls Outlook VBA and Custom Forms 4
C Difference between the TabStrip and MultiPage controls?? Outlook VBA and Custom Forms 2
MattC Changing the font of an email with VBA Outlook VBA and Custom Forms 0
C Outlook (desktop app for Microsoft365) restarts every time I save my VBA? Using Outlook 0
