Adding controls programmatically
Bishonen
Hi all,
Just two probably very Easy questions:
Is there a Chance to add controls to outlook forms programmatically on the go just lie can be done with vba userforms? Can I for example add two textboxes and a date picker when a commandbutton is executed?
And the second question: Ive created a form with a date control. Umfortunately it arrives at the receipient as 31.12.1989 or something like that regardless of what Has been truly selected. Any advice?
Yes, you can - start at http://support.microsoft.com/kb/238755 - it's for outlook 2000, but most forms stuff will work with 2007. See http://support.microsoft.com/kb/925192 for one thing that won't.
Outlook 2007 and up use forms regions, i don't have any samples handy for those but they can be programmed. If you are using all the old controls, then the first KB article will get you going.
M Adding controls in the Email Form Outlook VBA and Custom Forms 1
M Outlook 365 adding standard message in body of template email Outlook VBA and Custom Forms 3
S Adding Custom Forms Outlook VBA and Custom Forms 4
G Adding a contact to a specific folder Using Outlook 0
R Adding Userform Dropdown List items from names of subfolders on network drive Outlook VBA and Custom Forms 10
G Stop Outlook 365 adding meetings to calendar Using Outlook 1
G Removing old emails when adding accounts Using Outlook 3
D Contact Group - Adding Bulk Addresses Using Outlook 2
E Project Management - Adding Folders for Different Folder Types Using Outlook.com accounts in Outlook 0
O Adding a new account - "CompanyL (none)" line is added Using Outlook 5
W Adding A Macro To Message Ribbon Outlook VBA and Custom Forms 2
I Collecting mail address from GAB and adding to Outlook Task Using Outlook 2
A Outlook 2016 - adding outlook.com account creates a new/strange address Using Outlook.com accounts in Outlook 18
F Adding textbox filter to listbox? Outlook VBA and Custom Forms 2
J Adding Reply & Delete to main toolbar? Using Outlook 0
T Outlook 2007 adding categories Using Outlook 15
Diane Poremsky Adding Emojis to Outlook's AutoCorrect Using Outlook 0
T Adding "Mark As Complete" btton to Task Remindet Pop-Up Using Outlook 3
Ascar_CT Adding contacts on Android phone and then syncing them to Outlook Using Outlook.com accounts in Outlook 4
A Adding a 2010 sharepoint contact list to outlook 2010 address book Using Outlook 1
M Adding fields to Task in Outlook Home and Business 2010 Outlook VBA and Custom Forms 7
S Using Send on Behalf is adding extra data in from line Using Outlook 1
Lucylou Outlook 2013 Adding Outlook.com breaks profile, "Outlook not working" messag Using Outlook.com accounts in Outlook 1
C Adding Categories when Composing Email Using Outlook 1
