Programmatically scheduling WebEx meetings through Outlook
  • Thread starter Thread starter Barb Reinhardt
Barb Reinhardt
I have WebEx integrated into outlook and I periodically have to schedule
meetings for the year. Basically everything is the same but the date, so I'd
like to automate it. I've figured out how to schedule meetings, but haven't
got the WebEx meeting part figured out. Can it be done? If so, can you
direct me to some info on how to do this?
Barb Reinhardt
I'm afraid your request doesn't really have anything to do with Outlook
programming. If there's a COM API for WebEx, then you can use VBA or a COM
Add-In to automate it. See WebEx for support with their APIs though.
If you have questions about the Outlook object model specifically, feel free
to post your question.
Eric Legault - , MCDBA, MCTS (SharePoint programming, etc.)
> Thanks,
> Barb Reinhardt
Dr. Demento Programmatically encrypt email (2010) Using Outlook 10
oliv- Reduce the size of picture attachments: programmatically Outlook VBA and Custom Forms 3
B Adding controls programmatically Using Outlook 1
M programmatically make all Appointmentitem olResource Attendees unsendable Using Outlook 1
R Send appointments data to a Form programmatically Outlook VBA and Custom Forms 2
M How to connect to SQL DB from outlook programmatically? Outlook VBA and Custom Forms 1
N Help in programmatically setting formatting in an AppointmentItem Outlook VBA and Custom Forms 3
K Programmatically accessing Outlook properties Outlook VBA and Custom Forms 3
V How to programmatically set "Display reminders and tasks frm pstfolder Outlook VBA and Custom Forms 1
R Displaying a field from the field chooser programmatically Outlook VBA and Custom Forms 1
M How to programmatically select a outlook search folder? Outlook VBA and Custom Forms 1
M How to install custom mapi form programmatically? Outlook VBA and Custom Forms 1
A Programmatically duplicating BCM's "Link to Record" function BCM (Business Contact Manager) 2
B Accessing Outlook 2003 Signature Programmatically using C# Outlook VBA and Custom Forms 6
L Programmatically moving between pages in a form Outlook VBA and Custom Forms 2
S Programmatically bring up Advanced Find for contacts? Outlook VBA and Custom Forms 1
S assign task programmatically Outlook VBA and Custom Forms 2
S do Reply, Reply to All, Forward programmatically Outlook VBA and Custom Forms 2
L Sharing Calendar for Only Scheduling Using Outlook 2
C Outlook 2016 Username Not Working in Scheduling Assistant (Cache Mode) Using Outlook 0
Diane Poremsky Scheduling Drafts in Outlook Using Outlook 0
Diane Poremsky Scheduling a Recurring Message Using Outlook 0
F Scheduling Assistant in Outlook 2013 Using Outlook 0
J Exchange 2010 free/busy shows hashmarks in scheduling tab when not organizer Exchange Server Administration 6
D Outlook 2007 Scheduling assistant button missing Using Outlook 1
R Outlook Scheduling Assistant issue Using Outlook 2
C Scheduling mutiple, but identical, resources Using Outlook 2
B Scheduling a Meeting Resource (Room) with a conflict doesn't indicate any conflict on users calendar in Outlook 2007 Using Outlook 1
B How to Remove Scheduling and Tracking on the Custom Meeting Form Outlook VBA and Custom Forms 4
