Code to read emails
  • Thread starter Thread starter Mark Andrews
Mark Andrews
I wrote some Microsoft Access 2007 VBA code (see below) to read email
messages from an Outlook folder
and it seems to work fine on my computer.
I have Outlook configured to read from 2 POP/SMTP accounts and the mail
folder name I am passing in is
"personal folders\Inbox\Inquiries"
My client is using Exchange and trying to specify a folder as
"Mailbox-Personsname\Inbox\CRM Updates" and the she can't get the code to
work.
Question has anyone done this for Outlook 2007 configured to read from
Exchange or would you know what I might need to change?
My client is on the other side of the world so I'm finding it difficult to
debug. I don't do this kind of email reading very often.
Note: The client also has two email accounts setup and wants to read from
the non-default one.
Mark
Public Sub ReadMessagesFromMailFolder(MailFolderName As String)
On Error GoTo Err_ReadMessagesFromMailFolder
Dim RS As DAO.Recordset
Dim OlApp As Outlook.Application
Dim Olmapi As Outlook.NameSpace
Dim OlFolderMain As Outlook.MAPIFolder
Dim OlFolder As Outlook.MAPIFolder
Dim olItems As Outlook.Items
Dim Mailobject As Object
'Clear temp table
CurrentDb.Execute ("Delete * from tblOutlookMail")
'Create a connection to outlook
Set OlApp = CreateObject("Outlook.Application")
Set Olmapi = OlApp.GetNamespace("MAPI")
'Open the folder
Set OlFolder = GetFolder(MailFolderName)
'Set up the folders the emails are going to be deposited in
Set olItems = OlFolder.Items
Set RS = CurrentDb.OpenRecordset("tblOutlookMail")
'loop through mail items and add them to table
For Each Mailobject In olItems
With RS
> AddNew
!Subject = Mailobject.Subject
!From = Mailobject.SenderEmailAddress
!To = Mailobject.To
!Body = Mailobject.Body
!DateSent = Mailobject.SentOn
> Update
Exit_ReadMessagesFromMailFolder:
Set OlApp = Nothing
Set Olmapi = Nothing
Set OlFolderMain = Nothing
Set OlFolder = Nothing
Set olItems = Nothing
Set Mailobject = Nothing
Set RS = Nothing
Err_ReadMessagesFromMailFolder:
MsgBox Err.Description
Resume Exit_ReadMessagesFromMailFolder
Mark Andrews
RPT Software
http://www.rptsoftware.com
http://www.donationmanagementsoftware.com
Instead of coding like that use NameSpace.GetDefaultFolder(olFolderInbox) to
get the Inbox folder. That will work universally. Once you have the Inbox as
a MAPIFolder (Folder in Outlook 2007) you can then use code like this,
assuming oInbox is your Inbox: oInbox.Folders("CRM Updates")
"Mark Andrews" <mandrews___NOSPAM___@rptsoftware.com> wrote in message
news:OKp9XKE8KHA.5412@TK2MSFTNGP06.phx.gbl...
> work.
> Thanks,
> Mark
> 'Clear temp table
> 'Open the folder
> With RS
> .AddNew
> !To = Mailobject.To
> .Update
> End With
> Next
> Set OlApp = Nothing
> Set RS = Nothing
> Exit Sub
> End Sub
> > Mark Andrews
> RPT Software
Ken,
I had code like that and it did work. However I couldn't figure out how to
make it work for the folder the client wanted to use.
The client is very particular that it has to be the folder she wants.
She has 2 exchange accounts setup and if you look at her folders she has
- MailBox - XXX
Inbox is under this
- Mailbox - YYY
Inbox is under this
Let's assume XXX is the default mailbox, the code you indicate would goto
the Inbox of XXX and then you can reference subfolders.
How would I reference a folder under Mailbox - YYY?
Mark
news:O1tVljE8KHA.3964@TK2MSFTNGP05.phx.gbl...
> to get the Inbox folder. That will work universally. Once you have the
> Inbox as a MAPIFolder (Folder in Outlook 2007) you can then use code like
> this, assuming oInbox is your Inbox: oInbox.Folders("CRM Updates")
> > work.
> > to
>> Thanks,
> > Mark
>> 'Clear temp table
>> 'Open the folder
> > With RS
> > .AddNew
> > !To = Mailobject.To
> > .Update
> > End With
> > Next
> > Set OlApp = Nothing
> > Set RS = Nothing
> > Exit Sub
>> End Sub
>> > > Mark Andrews
> > RPT Software
The root folder of the mailbox would be Inbox.Parent. Just get Inbox and the
Parent property will point to the root folder (Outlook Today).
news:eCxFyyE8KHA.4604@TK2MSFTNGP04.phx.gbl...
> Ken,
> to make it work for the folder the client wanted to use.
> - MailBox - XXX
> Inbox is under this
> - Mailbox - YYY
> Inbox is under this
> Thanks,
> Mark
I'm sorry I still don't understand. She provided a screenshot which shows
three trees of folders.
the top three folders show:
- MailBox - XXX
- Mailbox - YYY
- Archive Folders
so Inbox.Parent would be MailBox - XXX
How do I retrieve folder "Mailbox - YYY\Inbox\CRMUpdates"?
Do I have to traverse two parents and then "Mailbox - YYY" and then "inbox"
and then "CRM Updates"?
In my Outlook I have "personal Folders\Inbox" so your logic makes sense for
my situation.
Mark
news:#8vERQF8KHA.4604@TK2MSFTNGP04.phx.gbl...
> the Parent property will point to the root folder (Outlook Today).
> > Ken,
> > - MailBox - XXX
> > Inbox is under this
>> - Mailbox - YYY
> > Inbox is under this
>> Thanks,
> > Mark
NameSpace.Folders has all the folders and stores. Each mailbox is a store,
as is a PST file (Personal Folders). If 3 stores are loaded (not counting
any public folders) NameSpace.Folders(1) would be one of them, etc. The
first one may not be the default though.
For each folder under a store you'd use a construct like Folder.Folders() to
get at subfolders.
Inbox.Parent would only apply to the default store. GetDefaultFolder() only
works for getting a default folder from the default store (where email is
delivered for the logged in user).
In a case such as you have you'd need to know the exact name and location of
every store and folder of interest. That hard coding of names would make it
impossible to make your code universal, you'd need to customize it for each
person and every variation of loaded stores, folders and folder names.
That's why almost all developers will fix names and folder locations.
news:eD9QtRG8KHA.1748@TK2MSFTNGP06.phx.gbl...
> - MailBox - XXX
> - Mailbox - YYY
> - Archive Folders
> "inbox" and then "CRM Updates"?
> for my situation.
> Thanks,
> Mark
Thanks Ken that makes sense! Now I just need to decide what I should do.
Mark
news:uC1LlOH8KHA.420@TK2MSFTNGP02.phx.gbl...
> to get at subfolders.
> only works for getting a default folder from the default store (where
> email is delivered for the logged in user).
> of every store and folder of interest. That hard coding of names would
> make it impossible to make your code universal, you'd need to customize it
> for each person and every variation of loaded stores, folders and folder
> names. That's why almost all developers will fix names and folder
> locations.
> > shows three trees of folders.
> > - MailBox - XXX
> > - Mailbox - YYY
> > - Archive Folders
> > for my situation.
>> Thanks,
> > Mark
Dr. Demento Analogous Outlook code to read info into an array (or collection or whatever) Outlook VBA and Custom Forms 7
R Need code snippet to read offline PST file Outlook VBA and Custom Forms 1
P How to get a QR code for automatic signin with Outlook for iOS Using Outlook 5
H Preventing the 'email address fetch from Exchange' crashing email reading code Exchange Server Administration 0
Alex Cotton "invalid or unqualified reference" on code that should work Outlook VBA and Custom Forms 5
D Command Button code will not execute. Any suggestions Please. Outlook VBA and Custom Forms 2
C Color Code New Calendar Items Using Outlook 2
