Outlook replacement form region using a "parent"
  • Thread starter Thread starter Tamas
Tamas
Hi *
I would like to implement a form replacement for outlook mail compose. That
displays the same form as the original mail composer, except that it injects
a new cntrol between the message and the subject. From VS .net environment.
Is this possible?
I know that outlook forms + VBS can does almost the same thing. Except that
it sends a winmail.dat, and buttons do not look exactly like in the original
compose form.
Is this possible? Or I must create a form and use the stupid vbs editor and
tools to develop this solution?
Thnx,
Tamas
Are you trying to create a mail form that can be sent and received and look
like what you designed? A Form Region would require registration of that
form region on every recipient's computer, preserving the data across the
Internet and various other things that require RTF and custom forms, and it
won't end up working right anyway the vast majority of the time.
See the information on sending custom forms over the Internet on
www.outlookcode.com. What you want to do would be even more unlikely to
work. And every recipient would have to use Outlook 2007 or later too.
I'd rethink your project, in my experience it just won't work in practice.
"Tamas" <Tamas> wrote in message
news:5063466E-18EF-4DD1-BDB6-7FDAD0CE803B@microsoft.com...
> Hi *
> That
> injects
> environment.
> Is this possible?
> that
> original
> compose form.
> and
> Thnx,
> Tamas
J Outlook replacement options - contact journal activities lost Using Outlook 23
O Hyperlink formatting lost after replacement in outlook Using Outlook 5
O Hyperlink formatting lost after replacement in outlook Using Outlook 0
L new outlook contacts searching Using Outlook 2
W New Outlook PEOPLE blank Using Outlook 7
C New Outlook issues with Gmail, particularly labels/folders Using Outlook 4
V Outlook created new profile? Using Outlook 1
J Outlook inbox question Using Outlook 4
M Anyone integrated AI website builders with Outlook for automated client communications? Using Outlook 1
V Gmail in Outlook Using Outlook 2
T Where has the Copilot icon gone in my Outlook desktop client? Using Outlook 6
P New way by Microsoft to get people to use the new Outlook Using Outlook 4
T Constantly Have To Log In To Outlook On The Web Using Outlook.com accounts in Outlook 2
O Outlook 2024 not showing that messages are replied to or forwarded Using Outlook 3
C I don't understand Outlook or Microsoft, anymore Using Outlook 12
P My Feedback to Microsoft and their response; also New Outlook roadmap Using Outlook 0
L Android Outlook Doesn't Update PC Notification Changes Using Outlook 0
D.Moore Outlook desktop client suggested searches question Using Outlook 22
Y Outlook 2016 (64-bit) Copy Local Cal. Events to Another Cal. with Modified Reminder time Using Outlook 2
D Cannot logon to Outlook.com, or outlook on Mac, outlook not updating on ipad, iphone Using Outlook 1
J unable to get my new install of Outlook to display mailboxes in the single-line format. Using Outlook 1
D Legacy Microsoft Outlook for Mac Support will end in Oct 2025 Using Outlook 8
C Nasty Bug Lurking In Outlook For Years. The Trigger. Any Fix Or Workaround? Using Outlook 12
R Auto clicking Hyperlink in outlook Outlook VBA and Custom Forms 7
G Outlook translation feature is off Using Outlook 2
