RSI and win7 - solutions?
danx55
hi guys,
yes i know - not purely outlook - but seems like a nice forum, so thought peeps might have ideas :)
i used win7 at work and have many program session open that i toggle between a lot - added to this there is much cutting and pasting going on - so my hands are starting to feel the strain :(
but im struggling to see how i can change how i use the pc to improve this - i need to reduce/change
the way i do ctrl+letter actions, alt+tabs etc - but not sure how
> ...im even considering buying dragon dictation software as i think it will allow my to set up scripts
to perform these actions
cheers
dan
> ....when will touch screens come to normal pcs i wonder - i think this might help
> ...the whole keyboard+mouse setup doesnt seem to have really improved much from what i have seen. it still seems very arduous to do many repetative actions on a pc - should be easier imo
ta
I know i can't think of anything useful - I'm assuming you are using Ctrl+A,C,V already and it would be very hard to automate it anymore. There are windows macro utilities such as AutoIt that might help with some repetitive tasks but unless the windows are the same each time, its going to be hard to automate copy and paste.
If you are copying from outlook to another program, try selecting nd draging text to other apps - it should work in any app that uses OLE.
hi Diane.
thanks for the reply. I will check out that program.
yes I use ctrl+c etc a lot but that is part of the problem I think :-D
was thinking along lines if a keyboard with smart keys that could be setup
to do cut copy plaster actions....if there is such a thing :-)
cheers
Dan
The Office keyboard from MS does have a copy and a paste key - and it may be enough to save your hands, but what would really save you is the ability to press one key to copy all in active document and paste all in some other document - pasting in the right document will be hard to script as will copying only a partial document.
FWIW, i have an older office natural keyboard - it has a zoom slider and all sorts of buttons (sleep, mail, media etc) but I never really used them. Because I used a laptop and a desktop, it was easier for me to use ctrl+c on the desktop than to keep switching how i did it. My new logitech has similar shortcuts, but require me to hold down the Fn key, so i don't really save any effort. <g>
hi again
thanks for info. will have to check out the ms
keyboard I think.
> ..also a one key press to show the running apps would be good imo
cheers
Dan
to the best of my recollection, you can assign programs to the keys, so you should be able to open task manager or similar using a keyboard that supports the special keys - which might be most MS keyboards plus some others.
One reason I switched from MS keyboards to logitech was because i wanted my function keys back - my previous keyboard had a function lock key that toggled the F keys between one touch shortcuts (including copy and paste) and F key functions. It defaulted to the shortcuts and i use F functions more often. The logitech defaults to F functions and i need to make an effect to toggle the special keys - that suits me just fine.
(The other reason I switched was because the logitech is quieter - i record training videos and the microsoft keys were loud clickity-clacks on the videos. A quiet keyboard would have won out over function key behavior though.)
ok cool thanks. probably need to see it demoed in shop if possible to see what it can do
I don't use fn keys so wont miss those :-)
thanks
W Outlook 2016 MSI - Possible to make work with O365 modern Auth & Win7? Using Outlook 4
J Outlook 2010 Outlook/Win7 Client logging Event ID 36887 Using Outlook 0
Witzker Has Outlook 2010 to be opened for Indexing Win7 Using Outlook 1
icacream reinstall outlook after new install win7 Using Outlook 2
W Importing .pst from Outlook 2010 (Win7) to Outlook 2013 (Win8.1) Using Outlook 2
mikecox Accessing Outlook on my Win7 desktop from Win8 laptop Using Outlook 1
Commodore 64-bit or 32-bit on 64-bit Win7? Using Outlook 0
Fozzie Bear Outlook 2010 wont remember Exchange Credentials on log off /shutdown of Win7 Exchange Server Administration 2
Commodore Outlook 2007 after Win7 from hibernation/sleep Using Outlook 2
G Transferring Office 2002 (XP) PST into Win7 (64) Office 2010 Using Outlook 1
D BCM install problem on Win7 BCM (Business Contact Manager) 3
E How to restore BCM Database after upgrade from Vista to Win7? BCM (Business Contact Manager) 1
J Program won't end in Win7 Outlook VBA and Custom Forms 1
D Win7 x64 - Outlook 2010Beta x64 - BCM 2010 x64 does not install BCM (Business Contact Manager) 1
