BCM install problem on Win7
David
windows 7 64bit
I purchased outlook 2007 with BCM and outlook installed fine, but not BCM.
When i ran the setup agin it tried to install BCM but fails. error: Setup
failed to install business contact manager for outlook 2007. a log file was
created and gives the file location.
The log file text is at the bottom if you want to take a look at it. So i
uninstall outlook, sql server 2005 express and all related. install Sql
express 2005 and verified that it is up and running, then install outlook
with bcm again. same exact result.
Tried again with Sql Express 2008 and sp1 but same results
it does create the MSSMLBIZ server and database but that's it.
David
=== Verbose logging started: 4/8/2010 10:05:40 Build type: SHIP UNICODE
5.00.7600.00 Calling process: C:\Windows\SysWOW64\msiexec.exe ===
MSI (c) (7C:00) [10:05:40:989]: Resetting cached policy values
MSI (c) (7C:00) [10:05:40:989]: Machine policy value 'Debug' is 0
MSI (c) (7C:00) [10:05:40:989]: ******* RunEngine:
******* Product: {B32C4059-6E7A-41EF-AD20-56DF1872B923}
******* Action:
******* CommandLine: **********
MSI (c) (7C:00) [10:05:40:994]: Client-side and UI is none or basic: Running
entire install on the server.
MSI (c) (7C:00) [10:05:40:994]: Grabbed execution mutex.
MSI (c) (7C:00) [10:05:41:033]: Cloaking enabled.
MSI (c) (7C:00) [10:05:41:033]: Attempting to enable all disabled privileges
before calling Install on Server
MSI (c) (7C:00) [10:05:41:058]: Incrementing counter to disable shutdown.
Counter after increment: 0
MSI (s) (04:20) [10:05:41:216]: Running installation inside multi-package
transaction {B32C4059-6E7A-41EF-AD20-56DF1872B923}
MSI (s) (04:20) [10:05:41:216]: Grabbed execution mutex.
MSI (s) (04:68) [10:05:41:221]: Resetting cached policy values
MSI (s) (04:68) [10:05:41:221]: Machine policy value 'Debug' is 0
MSI (s) (04:68) [10:05:41:221]: ******* RunEngine:
******* Action:
MSI (s) (04:68) [10:05:41:221]: Machine policy value 'DisableUserInstalls'
is 0
MSI (s) (04:68) [10:05:41:222]: MainEngineThread is returning 1605
MSI (s) (04:20) [10:05:41:223]: User policy value 'DisableRollback' is 0
MSI (s) (04:20) [10:05:41:224]: Machine policy value 'DisableRollback' is 0
MSI (s) (04:20) [10:05:41:224]: Incrementing counter to disable shutdown.
MSI (s) (04:20) [10:05:41:224]: Note: 1: 1402 2:
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
MSI (s) (04:20) [10:05:41:225]: Note: 1: 1402 2:
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\InProgress 3: 2
MSI (s) (04:20) [10:05:41:225]: Decrementing counter to disable shutdown. If
counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI (s) (04:20) [10:05:41:226]: Restoring environment variables
MSI (c) (7C:00) [10:05:41:229]: Decrementing counter to disable shutdown. If
MSI (c) (7C:00) [10:05:41:231]: MainEngineThread is returning 1605
=== Verbose logging stopped: 4/8/2010 10:05:41 ===
Raul Thomas
Hello David
Can you share a copy of the MSSsetup.log from the %temp% folder ?
Also can I get you to delete the "Business solutions Ecrm" entries at the
following two locations…
Hkey_Local_Machine Software WOW6432Node Microsoft
Hkey_Current_User Software WOW6432Node Microsoft
and re-run the setup
Regards
Rahul Thomas
MSFT
"David" <David> wrote in message
news:03DFE497-B2BE-4C4D-89B6-57F647A40E86@microsoft.com...
> windows 7 64bit
> was
> David
> ******* Action:
> Running
> privileges
> ******* Action:
> is 0
> 0
> 3: 2
> 3: 2
> 3: 2
> 3: 2
> If
> If
Michael Shear
I've hadthe same problems installing BCM for Office 2007 on Windows 7. I need
more concrete steps on what to do from here.
Uninstall Office? Outlook? All SQL 2005 programs? Remove registry keys?
Which ones?
I need step by steps not piecemeal information!!!
Michael S
"Raul Thomas" wrote:
> Hello David
> > Regards
> Rahul Thomas
> MSFT
> > windows 7 64bit
> > was
> > David
> > ******* Action:
> > Running
> > privileges
> > ******* Action:
> > is 0
> > 0
> > 3: 2
> > 3: 2
> > 3: 2
> > 3: 2
> > If
> > If
Raul Thomas
Hi Michael
I guess you need to be more description of the error :) , only than can
someone help you
If the installation is failing , is it failing on the Business contact
manager or the SQL part ?
What version of windows are we trying to install the application on 32 or 64
Regards
Rahul Thomas
MSFT
"Michael Shear" <Michael Shear> wrote in message
news:8089FF60-3789-4F1A-8C42-A6EA37CF3E6B@microsoft.com...
> need
> Which ones?
> Michael S
> > Hello David
> > > > Regards
>> Rahul Thomas
>> MSFT
> > > windows 7 64bit
> > > BCM.
> > > Setup
> > > file
> > > was
> > > So i
> > > Sql
> > > outlook
> >> > David
> > > UNICODE
> > > ******* Action:
> > > Running
> > > privileges
> > > shutdown.
> > > multi-package
> > > ******* Action:
> > > is 0
> > > 0
> > > is
> > > 0
> > > shutdown.
> > > 3: 2
> > > 3: 2
> > > 3: 2
> > > 3: 2
> > > shutdown.
> > > If
> > > shutdown.
> > > If
J Install BCM Client without an local SQl Database BCM (Business Contact Manager) 6
Chris Grew How Long To Install BCM BCM (Business Contact Manager) 2
D 2013 BCM Won't Install BCM (Business Contact Manager) 1
T Office2013 and BCM on Windows 8.1 -- install of BCM does not work? BCM (Business Contact Manager) 2
O RE-install of BCM and previous sync profile conflicts BCM (Business Contact Manager) 3
S BCM Install Issues BCM (Business Contact Manager) 2
L Cannot install BCM 2010-"Outlook 2010 Not Installed" but it is! BCM (Business Contact Manager) 1
T BCM Install fails Both w Off. Pro 2010 Beta & on reinstall Off.Pro BCM (Business Contact Manager) 5
T Install BCM on SBS 2008 Standard server BCM (Business Contact Manager) 1
S Trying to install BCM 2010 x64, getting error BCM (Business Contact Manager) 8
E Install BCM on windows 7 BCM (Business Contact Manager) 2
H Fail to install BCM 2007 (English) on Windows 7 64 bit (Danish) BCM (Business Contact Manager) 3
D Win7 x64 - Outlook 2010Beta x64 - BCM 2010 x64 does not install BCM (Business Contact Manager) 1
T Can I install BCM on 2 computers w/o buying 2 copies? BCM (Business Contact Manager) 1
S BCM in Office Ultimate 2007 Won't Install on W7 Ultimate 32 BCM (Business Contact Manager) 1
A What to do if BCM didn't install with 2007 Professional Trial? BCM (Business Contact Manager) 1
J Install BCM on Windows Vista BCM (Business Contact Manager) 3
S BCM install fails at SQL install BCM (Business Contact Manager) 1
K BCM and Service Pack Install Problems BCM (Business Contact Manager) 1
N Can I install BCM client without SQL Express? BCM (Business Contact Manager) 1
E Re:BCM failed to install in outlook 2007 due to SQL Server Express 20 BCM (Business Contact Manager) 1
M BCM did not install BCM (Business Contact Manager) 1
R Office 2007 SP2 Install: BCM Update Failure BCM (Business Contact Manager) 25
S Can't install BCM in Ofiice Pro Trial BCM (Business Contact Manager) 4
