BCM did not install
Mike User1
- Got New Machine
- Used the Upgrade disks that I had from my old (nearly dead now) machine to
install MS office small business. Office installed fine (didn't ask me for
older disks of office XP that I had)
- Copied over all the PST files and setup Outlook and all is well But ...
- The new install of Outlook however doesn't have the BCM on it, not on the
menu, or anywhere
- Can't add a BCM database from control panel mail or program (not listed as
an option).
So I think BCM just never installed. How do I install it?
Mike User1
Problem resolved. There must have been some error along the way as the
reinstall finally worked :)
"Mike User1" wrote:
> - Got New Machine
> menu, or anywhere
> an option).
R Installing BCM BCM (Business Contact Manager) 0
G Future development of BCM BCM (Business Contact Manager) 5
