Code to move mail with certain attachment name? Does Not work
Cody99
Outlook 365 64 bit
I'm stuck on some code I want to run in outlook. Firstly, I can't understand when it runs, seems to be when I start outlook, but I can't step through the code in the VBA editor either.
Then I get = nothing on "objTargetFolder" when it is run.
The reason is that I receive e-mails that differ only in the name of the attachment, and that does not solve common rules in Outlook. So one of the attachments is called, for example, CALLS DAILY, I'll look for that in incoming mail attachments in the inbox Then I'll move that mail in that case to the inbox/outlookdata/Calls daily
Then the same with a few different variations on attachment names for different folders. ("report" and "statistics" code I haven't changed yet.)
can anyone see why "objTargetFolder" = nothing when run. Can't find the right folder?
Public WithEvents objMails As Outlook.Items
Set objMails = Outlook.Application.Session.GetDefaultFolder(olFolderInbox).Items
Private Sub objMails_ItemAdd(ByVal Item As Object)
Dim objAttachments As Outlook.Attachments
Dim objAttachment As Outlook.Attachment
Dim strAttachmentName As String
Dim objInboxFolder As Outlook.Folder
Dim objTargetFolder As Outlook.Folder
'Ensure the incoming item is an email
If TypeOf Item Is MailItem Then
Set objMail = Item
Set objAttachments = objMail.Attachments
'Check if the incoming email contains one or more attachments
If objAttachments.Count > 0 Then
For Each objAttachment In objAttachments
strAttachmentName = objAttachment.DisplayName
Set objInboxFolder = Application.Session.GetDefaultFolder(olFolderInbox)
'Check the names of all the attachments
'Specify the target folders
If InStr(LCase(strAttachmentName), "CALLS DAILY") > 0 Then
Set objTargetFolder = objInboxFolder.Folders("Mitt.namn@min-epost.com").Folders("OutlookData").Folders("CALLS DAILY")
ElseIf InStr(LCase(strAttachmentName), "report") > 0 Then
Set objTargetFolder = objInboxFolder.Folders("Report")
ElseIf InStr(LCase(strAttachmentName), "statistics") > 0 Then
Set objTargetFolder = objInboxFolder.Folders("Statistics")
I can see that the code sees the attachment in an incoming mail:
But in the next step i cant recognize the "move to" folder?
The folder is named exactly the same and is located -> inbox/OutlookData/callsdaily
So i got a bit further, i use parent.folder and it works sometimes, but not all the time?
Relly no one in the vast forum that can help me? :)
Its really strange that it works now and then, but not always.
Also when is the code active? only once after a restart of outlook?
No sometimes it runs when an emal arrives, but sometimes it dosent?
This is my code now:
    'MSGbox just to se wehn scrip runs.
    MsgBox "Script running"
       Set objMail = Item
              If InStr(LCase(strAttachmentName), "calls daily") > 0 Then
                 Set objTargetFolder = objInboxFolder.Parent.Folders("OutlookData").Folders("calls daily")
              ElseIf InStr(LCase(strAttachmentName), "calls mtd") > 0 Then
                 Set objTargetFolder = objInboxFolder.Parent.Folders("OutlookData").Folders("calls mtd")
              'ElseIf InStr(LCase(strAttachmentName), "statistics") > 0 Then
              '   Set objTargetFolder = objInboxFolder.Folders("Statistics")
         'Move the email to specific folder
          objMail.Move objTargetFolder
T What code to use to move the custom field values to message body when sending e-mail ? Outlook VBA and Custom Forms 8
Dr. Demento Analogous Outlook code to read info into an array (or collection or whatever) Outlook VBA and Custom Forms 7
P How to get a QR code for automatic signin with Outlook for iOS Using Outlook 5
H Preventing the 'email address fetch from Exchange' crashing email reading code Exchange Server Administration 0
Alex Cotton "invalid or unqualified reference" on code that should work Outlook VBA and Custom Forms 5
D Command Button code will not execute. Any suggestions Please. Outlook VBA and Custom Forms 2
C Color Code New Calendar Items Using Outlook 2
