How to get a QR code for automatic signin with Outlook for iOS
PhilBurton
OS Version(s)
  1. Windows
Outlook 365 64 bit
Between us my wife and I have two iPhones and two iPads on which we want to use Outlook for iOS. The initial screen for Outlook for iOS refers to a QR code "on your computer," but it's not clear how I get this code. I expected an email from MS, but I haven't gotten one. That would save a lot of time, including typos, doing password entry.
I'm hoping to use Outlook for iOS to get around the complete message with iTunes synchronization for Outlook.
It's here - https://outlook.live.com/mail/0/options/general/mobile
Isn't that what it does?
Ok... in Outlook mobile app, click on the Add account button (skip adding accounts the app knows about) - then in the upper right corner, click the QR code icon. Then scan the code to add the account to Outlook.
T Code to import address book in automatic mode Outlook VBA and Custom Forms 1
H Preventing the 'email address fetch from Exchange' crashing email reading code Exchange Server Administration 0
Alex Cotton "invalid or unqualified reference" on code that should work Outlook VBA and Custom Forms 5
D Command Button code will not execute. Any suggestions Please. Outlook VBA and Custom Forms 2
C Color Code New Calendar Items Using Outlook 2
S my vbscript button1_click code works on appointment created but not on opening an existing apntmn Outlook VBA and Custom Forms 16
M regarding the Create Contacts From Messages code Using Outlook 8
D VBA Code to strip Subject Line when replying or forwarding Using Outlook 3
