Autoarchive questions
awardb
OS Version(s)
  1. Windows
Outlook 2021 64 bit
Operating system::    WIndows 11
Outlook version:     2021 Classic
Email type or host:    POP
I have been using Outlook Desktop for well over 20 years. Current version 2021. I have a question that I've never found an answer for in all of that time. I have AutoArchive turned on, and it pops up a warning every 30 days. However, I have to click "no" to the pop-up, because what I WANT it to do is to autoarchive all of my folders using the custom settings I've created for each folder, NOT the default Microsoft settings. So then after I say "no" to the popup that autoarchive is about to run, I have to manually go into Outlook ,and tick the box that says "Archive all folders according to their autoarchive settings". Why isn't there a way to have Outlook choose THAT option every time it runs autoarchive INSTEAD of running the default Microsoft settings on each folder. This change seems so simple to me, but in over 20 years of looking I've been unable to find a way to have Outlook do that. Help, please!
Outlook doesn’t let AutoArchive automatically use your custom per-folder settings — it always runs the global default. To fix this, first turn off automatic AutoArchive in File > Options > Advanced > AutoArchive Settings. Then, you can use a small VBA script that runs “Archive all folders according to their AutoArchive settings” and schedule it with Windows Task Scheduler. This way, your folders get archived exactly how you want without manually clicking anything.
I will assume that things have changed over the years, because my very old Outlook Classic works exactly like awardb wants it to.
File -> Options -> Advanced -> [AutoArchive Settings ...]
And from my notes I have to myself
Victor_50 Set all subfolders to not autoarchive Outlook VBA and Custom Forms 11
Diane Poremsky Using Outlook's AutoArchive Feature Using Outlook 0
E Moving autoarchive settings to new computer (Outlook 2007) Using Outlook 1
K Revert AutoArchive settings via GPO (Run Autoarchive every...) Using Outlook 4
B AutoArchive Nuances Using Outlook 1
R Get AutoArchive settings (as set from Tools|Options|Other|AutoArch Outlook VBA and Custom Forms 1
B Update AutoArchive Settings on Multiple PST Files Outlook VBA and Custom Forms 5
M Can't change autoarchive property in Deleted Items folder BCM (Business Contact Manager) 1
S Mac Outlook 365 Questions Using Outlook 1
P Questions On Crashing, Sluggish, and Configurations Using Outlook 1
J Diane's Delay Delivery at Specific Times Questions Outlook VBA and Custom Forms 7
D Outlook for Android Questions Using Outlook 8
O flagging replies - several questions Using Outlook 2
P Moving PST file questions Using Outlook 3
Y PST file questions Using Outlook 1
D Questions related to usage of webpage in outlook Using Outlook 1
G Questions on creating Outlook forms Using Outlook 0
O x86 vs. x64 Sql Server 08 Dbase Questions BCM (Business Contact Manager) 2
Jennifer Murphy Questions about ANSI-Unicode PST conversion article Using Outlook 2
J Multiple Outlook questions Using Outlook 2
P Field option selection resulting into multiple questions BCM (Business Contact Manager) 0
S Questions about Calendar Notifications Using Outlook 1
H Couple of 2007 Calendar questions Using Outlook 1
K CPA - Office 2010 - 64 bit Questions Using Outlook 1
S Couple of questions related to calender Using Outlook 1
S Seperating email accounts, Syncronizing, and a few newbie questions Using Outlook 5
T Outlook 2010 Mutliple Exchange Accounts SET UP QUESTIONS Using Outlook 4
E Questions on the OutlookRibbonXCS example Outlook VBA and Custom Forms 4
T Ribbon Control questions Outlook VBA and Custom Forms 7
K Scraping outlook emails (2 questions) Outlook VBA and Custom Forms 1
