Ribbon Control questions
  • Thread starter Thread starter Tom
Tom
Hi All,
I have a few questions about the ribbion control.
1. How do I query for my ribbon control at run time? What interface am I
supposed to use?
2. Can I add/remove items dynamically at runtime from a ribbon control
combobox?
3. Are there and C++ (or VB) examples anywhere that fully demonstrate all
the controls?
Tom
It's hard to be specific since you didn't mention what version of Outlook,
what version of VS, what version of VB, whether this is for unmanaged or
managed code and if managed whether a shared addin or a VSTO addin, or much
of anything else.
There's no one article that I've seen that covers everything and every
variation of handling things with the ribbon, but start with the article at
http://msdn.microsoft.com/en-us/library/aa338202.aspx. You can also go to
the Office Developer Web site at MSDN and download a lot of information,
references of ribbon id's, samples and so on.
"Tom" <tom@gigasoftdevelopment.com> wrote in message
news:u0YCA9utKHA.732@TK2MSFTNGP06.phx.gbl...
> Hi All,
> supposed to use?
> combobox?
> the controls?
> Thanks,
> Tom
Sorry Ken - I am using unmananged code (ATL/C++) and all my add-ins support
Outlook 2000 and above - and any operating systems. Oh - and I am using VS
2008.
I am particularily interested in adding items and controls dynamically at
runtime.
Actually I saw that article you mentioned and it is fine if you want to
statically create controls.
I have searched the net and have not found any articles about adding
combobox items at run time. Can we do that? Can I query the interface from
the application object or inspector?
Tom
news:evIwhCvtKHA.5008@TK2MSFTNGP05.phx.gbl...
> much of anything else.
> at http://msdn.microsoft.com/en-us/library/aa338202.aspx. You can also go
> to the Office Developer Web site at MSDN and download a lot of
> information, references of ribbon id's, samples and so on.
> > Hi All,
> > supposed to use?
> > combobox?
> > the controls?
>> Thanks,
> > Tom
There's limited support for doing much dynamically with most of the ribbon
controls. There are also limited resources for documentation on working in
unmanaged C++, most of the code samples are in C# or VB.NET, only a few in
VB6. I believe there is some C++ at www.outlookcode.com.
I mostly use a dynamicMenu control when I want something to be truly
dynamic. As far as adding members to the combobox ore dropdown list, that
can be done to a degree. You can't really query the interface, but you can
force callbacks by invalidating that control or all of your controls using
InvalidateControl("myControl") or InvalidateControls().
I've used dropdown controls with their onAction, getItemCount, getItemID,
getItemLabel and getSelectedItemIndex callbacks to control the list at
runtime. For example creating a dropdown control and displaying a list of
email accounts. Similar things can be done with combos.
For handling Outlook 2000 and above things are different in C++, but for C#
I use a modified set of COMImport statements derived from an article on
Andrew Whitechapel's blog. Andrew used to be on the VSTO team. That article
is at
http://blogs.msdn.com/andreww/archi...or-multiple-office-versions-without-pias.aspx
and there's also a followup article. For VB6 code I use a tlb derived from
the Office 2007 library that exposes the ribbon interfaces
(XLIRibbonExtensibility.tlb) from XL-Dennis's Web site.
news:OwJruJvtKHA.4908@TK2MSFTNGP06.phx.gbl...
> support Outlook 2000 and above - and any operating systems. Oh - and I am
> using VS 2008.
> runtime.
> Thanks,
> Tom
That is what I thought ken.
But I never thought about invalidating to force a callback - good idea!
I have so many customers who don't like to use the add-in tab for Outlook
2007 because it hides their obvious logic. So they want something visible
that says their company name.
FYI- Also I have numerous requests to add a simple button next to the send
button on the new message window. Are we ever going to be able to do this?
We have actually had clients change their mind about doing anything with
Outlook because of that one lacking feature. For example some companies like
button functionality like -"Send and save on network". And they want it
next to the send button. I think this is one feature that needs to be added
to Outlook.
Thanks again for your input.
news:e28EGxvtKHA.4332@TK2MSFTNGP05.phx.gbl...
> C# I use a modified set of COMImport statements derived from an article on
> article is at
> > using VS 2008.
> > runtime.
> > from the application object or inspector?
>> Thanks,
> > Tom
The Add-Ins tab entries have no discoverability.
It's worse in Outlook 2010 because you also have that for Explorers. In
addition, what you used to add to property pages now is also not
discoverable unless you re-write to use Backstage instead.
To support various versions I now have Inspector ribbons and commandbars,
Explorer ribbons and commandbars, property pages and Backstage all supported
in one addin dll. Lots of version testing and special case code.
You cannot add anything to the big Send button area, nor can you repurpose
that button as you can with most other ribbon controls. My customers have
had to accept either a new ribbon group or tab for that. My information is
that there is no thought to allowing us to customize that button or that
area.
I hate to suggest it, but if there's no compromise you might have to use
start from scratch and design your own ribbon for customers like that from
scratch where you can design what they want. Of course the development costs
may make them decide they'd love the button somewhere else :)
With invalidating you have to check and see which callbacks are forced by
invalidating. Some are not called again, some are, depending on the control
and the callback. So you have to test for suitability for your purposes.
news:OZwly4vtKHA.5036@TK2MSFTNGP02.phx.gbl...
> like button functionality like -"Send and save on network". And they want
> it next to the send button. I think this is one feature that needs to be
> added to Outlook.
Yep - I have already run into the testing debacle. It is really becoming a
pain. We really started to add testing all of our custom addins proposals.
It takes a long time to test each version.
I sometimes wish we could install multiple versions of Outlook on one
desktop (same with IE).
news:OIAktIxtKHA.3408@TK2MSFTNGP06.phx.gbl...
> supported in one addin dll. Lots of version testing and special case code.
> area.
> costs may make them decide they'd love the button somewhere else :)
> control and the callback. So you have to test for suitability for your
> purposes.
> > send button on the new message window. Are we ever going to be able to do
> > this? We have actually had clients change their mind about doing anything
> > with Outlook because of that one lacking feature. For example some
> > companies like button functionality like -"Send and save on network".
> > And they want it next to the send button. I think this is one feature
> > that needs to be added to Outlook.
R Outlook ribbon menu default? Using Outlook 7
L Getting Index from dropdown inserted on ribbon Outlook VBA and Custom Forms 3
e_a_g_l_e_p_i Trying to customize the ribbon but can't figure this one out Using Outlook 3
Witzker Customized Ribbon lost every now and then Using Outlook 3
Witzker Customized ribbon and entries disappeared Using Outlook 0
W Ribbon XML customization Using Outlook 4
M Simplified ribbon missing Using Outlook 3
L Outlook Office 365 client: won't remember my setting File, not to collapse ribbon Using Outlook 2
I Retention policies on outlook 2016 ribbon Using Outlook 2
Wayne Dardis Calling Ribbon Button in Outlook 2016 Outlook VBA and Custom Forms 6
W Adding A Macro To Message Ribbon Outlook VBA and Custom Forms 2
Diane Poremsky Customize the Outlook Toolbar, Ribbon or QAT Using Outlook 0
M No Show Group on ribbon Using Outlook 8
I Ribbon buttons grayed-out in Outlook 2013 Using Outlook 2
B How can I adjust the ribbon width? I want to see all of my Quick Steps. Using Outlook 1
piusg 2013: Place custom view on the ribbon Using Outlook 3
P Outlook 2007 Calendar Ribbon has changed and I can't fix it Using Outlook 10
R Can I create custom subgroups on the ribbon? Using Outlook 5
M missing iCloud tab on ribbon bar Using Outlook 0
G Adding 3rd-Party Add-In to Home Ribbon in Outlook 2010 Using Outlook 1
E Outlook Ribbon Customization and Deployment Using Outlook 1
C Outlook Calendar Ribbon with iCloud Using Outlook 2
S ADD-IN Ribbon Missing Using Outlook 2
S ADD-IN Ribbon Missing Using Outlook 5
S Outlook 2010 Ribbon - Creating Links To Websites or EXE Files Using Outlook 4
K call a help file when click on a button xml ribbon Outlook VBA and Custom Forms 1
J Executing Ribbon Command from Code Outlook 2010 Outlook VBA and Custom Forms 3
T Word 2007 add-in ribbon icons greyed out Outlook VBA and Custom Forms 1
K add a designed group into a existing inspector ribbon Outlook VBA and Custom Forms 7
C Create a Ribbon for the OL2010 Explorer Outlook VBA and Custom Forms 1
S What's the appointment ribbon called? Outlook VBA and Custom Forms 1
H Program "Click on Ribbon Button" Using VBA Outlook VBA and Custom Forms 1
M Can I embed ribbon item into form region? Outlook VBA and Custom Forms 2
R Build custom ribbon in Outlook 2007 Outlook VBA and Custom Forms 3
C Ribbon problem Outlook VBA and Custom Forms 3
J Ribbon question Outlook VBA and Custom Forms 6
R Could i do this with ribbon(outlook2007)? Outlook VBA and Custom Forms 1
M Stop ribbon item tool tip text from wrapping? Outlook VBA and Custom Forms 2
T Ribbon and a checkbox (C++ ATL) Outlook VBA and Custom Forms 8
H access appointmentItem from ribbon menu Outlook VBA and Custom Forms 1
D Application.ActiveInspector() is Null on Ribbon Load Outlook VBA and Custom Forms 1
T Using Ribbon in Inspector window Outlook VBA and Custom Forms 2
