Create a Ribbon for the OL2010 Explorer
  • Thread starter Thread starter ChristianH
C
ChristianH
I want to create a Ribbon for the Outlook 2010 Explorer. I am looking for a
sample XML description.
Can anybody give me a tipp?
Christian
Have you downloaded the samples for Outlook addins from Connect? They show
how Explorer ribbon XML. There are also downloads for the ribbon id's.
"ChristianH" <ChristianH> wrote in message
news:A8A847C5-810E-4B14-BEF4-37D6C5646574@microsoft.com...
> Hi,
> a
> Thanks
> Christian
R Can I create custom subgroups on the ribbon? Using Outlook 5
T Create a group from a large To distribution list Using Outlook 3
