Build custom ribbon in Outlook 2007
  • Thread starter Thread starter Robert k
Robert k
Is there a way to build a custom ribbon in Outlook 2007 without purchasing
Visual Basic or C# apps? I searched the Internet and could only find a
reference that using Visual Basic or C# in the Visual Studio 2005 suite is
needed for the add-in. Further, Visual Basic Express does not have all of
the features needed and therefore it could not be used. Can a ribbon be
built without spending $ for these apps?
The only way to work with the ribbon in Outlook 2007 is with a COM addin.
What language you use doesn't matter as long as it can create a COM addin
for Outlook.
"Robert k" <Robertk> wrote in message
news:A7778962-4EAA-4D1B-87A2-6A3E4A1C427F@microsoft.com...
Thanks Ken...I appreciate the feedback. Do you know of any COM add in apps
that are freeware?
Robert k
> for Outlook.
What do you mean by COM addin apps that are freeware? Are you looking for
free COM addins or a free development language? I know of no development
language that can be used to develop COM addins that is free, but I don't
know every language out there.
news:F61253A0-C858-46AC-8647-9931492232C7@microsoft.com...
> apps
> that are freeware?
> > Robert k
L Ever notice that the fonts in Outlook seem to be depend on the build? Using Outlook 1
wallisellener BCM new Build? BCM (Business Contact Manager) 8
D Custom Form Overwritten? Outlook VBA and Custom Forms 20
D Custom form now unusable Outlook VBA and Custom Forms 1
H Outlook 2016 Custom made "Message" column Outlook VBA and Custom Forms 7
sjbtax Update Task Custom Field based upon Task Overdue Status Outlook VBA and Custom Forms 8
A How to reduce size of custom contact form? Outlook VBA and Custom Forms 3
S Adding Custom Forms Outlook VBA and Custom Forms 4
N "Perform a Custom Action" Outlook VBA and Custom Forms 0
