Re: Business Contact Does Not Delete
  • Thread starter Thread starter Gary P
G
Gary P
On Jun 29, 11:42 am, Luther Blissett <enown...@gmail.com> wrote:
> On Jun 25, 12:33 pm, Gary P <g.poll...@gmail.com> wrote:
> > Hello,
> > We are having some problems with BCM 07.  The issue is that when we do
> > a large amount of data entry/deletion on the database some information
> > doesn't sync up.  For instance, we delete 100 records and the next day
> > 5 are still there.
> > We are running BCM in a local environment, off a "server PC" running
> > XP.  Accessing the database w/4 or 5 workstations at a time, database
> > is at 12K records.  No mobile sync w/database.
> > Thanks for your help,
> > Gary
> When you say does not delete, you mean the deleted item does not move
> to the Deleted Items folder?
Yes, items appear to move to the deleted items folder, but a few days
later they reappear in the database.
> If several user update a record. Let's say one user deletes the a
> contact and a second user updates the contact (e.g. because they
> received an email from that contact), then if the second event
> happened later (has a later ModifiedOn value), that may explain the
> behavior you are seeing.
We're pretty careful in this regard - we've coordinated data efforts
so that there is minimal overlap. It just happened again, some
duplicate records we deleted are not staying in the deleted items
folder. When we choose "Delete" they are removed from the business
contacts database, so it must be a sync problem. I'm hoping a memory
boost to the server pc will help.
> > > Hello,
> > > We are having some problems with BCM 07.  The issue is that when wedo
> > > 5 are still there.
> > > Gary
> boost to the server pc will help.- Hide quoted text -
> - Show quoted text -
When an item is "soft" deleted (moved to deleted items folder), in the
database its record is marked as deleted. I believe there's a column
for just that.
When an item is deleted from the deleted items folder then it's "hard"
deleted, and the record actually deleted from the database.
There may be some rules in BCM -- along the lines of: if an activity
is updated, and one its parents is soft deleted, then undelete it that may explain the behavior you're seeing.
Note that synchronizing data between several actors is an NP-complete
problem, so some simple but imperfect rules have to be used. For
example, if two users both change an entity, the most recent change
wins.
B RE: Why does Business Office Contact Manager shut down Outlook? BCM (Business Contact Manager) 3
jehan2256 "History" button in Business Contact Manager Using Outlook 1
P How to filter primary contacts in business contact manager BCM (Business Contact Manager) 0
C Business Contact Manager Using Outlook 3
O Calendar and business contact manager Using Outlook 0
N Select Existing BCM Business Contact in C# application Using Outlook 0
N BCM suddenly crashed and not able to view specific business contact. Using Outlook 1
L Business Contact Mnager losing contact details BCM (Business Contact Manager) 1
C Trying to move my Business Contact Manager ver. 2003 to BCM ver. 2010 Using Outlook 3
D opening Word Document in a business contact? BCM (Business Contact Manager) 3
A receive error when create new business contact BCM (Business Contact Manager) 14
M Looking for trainer in Business Contact Manager BCM (Business Contact Manager) 0
M Queries on Business Contact Manager (BCM) with Outlook 2013 Using Outlook 1
V Custom UI Runtime Error in Business Contact Manager for Outlook (2013) BCM (Business Contact Manager) 6
R "business contact manager logon failure server is in single user mode" - HELP! BCM (Business Contact Manager) 4
R Adding Second Business Contact Group BCM (Business Contact Manager) 1
P Business Contact Manager without Exchange? BCM (Business Contact Manager) 1
G Sharing Business contact manager BCM (Business Contact Manager) 5
K add an email to a business contact without linking/tracking sender BCM (Business Contact Manager) 0
T Merging multiple Business Contact Manager files BCM (Business Contact Manager) 0
C Looking for way to tie a Business Contact to more than one Account BCM (Business Contact Manager) 5
C placing contact and business phone column in task view Using Outlook 1
U business contact manager add in Using Outlook 1
M Business Contact Manager Marketing Campaign default address BCM (Business Contact Manager) 0
G Print from business contact history item BCM (Business Contact Manager) 0
S Business Contact Manager (BCM) causing Outlook crash loop BCM (Business Contact Manager) 3
K Business Contact Manager add-on for Windows 7 Professional Plus? BCM (Business Contact Manager) 3
A Can Business Contact Manager be downloaded seperately? BCM (Business Contact Manager) 1
D Downloaded ultimate 2007 - Can't Find Business Contact Manager BCM (Business Contact Manager) 1
A Business Contact Manager Error BCM (Business Contact Manager) 1
D business contact manager did not install with outlook 7 BCM (Business Contact Manager) 2
H I have installed Business Contact Manager but cannot find to use BCM (Business Contact Manager) 1
N Business Contact Manager - Ability to use BCM (Business Contact Manager) 8
C "Business Contact Manager for Outlook could not connect to db BCM (Business Contact Manager) 1
J outlook 2003 business contact manager BCM (Business Contact Manager) 1
C Moving Business Contact Manager to Pro Plus, dropping Accounting BCM (Business Contact Manager) 1
R My email merge/business contact manager fields are not populating BCM (Business Contact Manager) 1
C Business Contact manager wont open BCM (Business Contact Manager) 1
G Task / Insert / Attach Item / Business Contact BCM (Business Contact Manager) 1
N How do you share your business contact manager with coworkers BCM (Business Contact Manager) 1
A Microsoft Office 2003 Business Contact Manager and Windows 7 BCM (Business Contact Manager) 1
C Outlook Business Contact Manager Beta Not Working BCM (Business Contact Manager) 2
G Training on Business contact manager BCM (Business Contact Manager) 1
R RE: Business Contact manager failed to install BCM (Business Contact Manager) 1
C Business Contact Manager BCM (Business Contact Manager) 2
C Business Contact Manager 2007 - Windows 7 BCM (Business Contact Manager) 1
