VSTO outlook 2007 addin installation problem
  • Thread starter Thread starter Nagaraj
N
Nagaraj
I am developing outlook 2007 VSTO plugin and using SetSecurity project also.
In SetSecurity.cs file
I have the following line.
try
// The solutionCodeGroupName must be a unique name;
otherwise, the method might delete wrong code group.
CaspolSecurityPolicyCreator.RemoveSecurityPolicy(allUsers,
solutionCodeGroupName);
catch (Exception e)
MessageBox.Show("StackTrace " + e.StackTrace);
While executing above line
I am getting error.
StackTrace at
CustomActions.CaspolSecurityPolicyCreator.RunCaspolCommand(String
frameworkFolder, String arguments)
at CustomActions.CaspolSecurityPolicyCreator.RemoveSecurityPolicy(Boolean
machinePolicyLevel, String solutionCodeGroupName)
at CustomActions.SetSecurity.Install(IDictionary stateSaver)
and I am getting error Code 2869.
The installer has encountered an unexpected error installing this package.
This may indicate a problem with this package. The error code is 2869.
The installer is rolling back.
Before AddSecurityPolicy, RemoveSecurityPolicy with the
solutionCodeGroupName is failing.
Can anyone tell me how to fix this problem.
Thanks in advance.
Nagaraj Tadipatri
My system configuration is
Windows XP Professional Version 2002 Service Pack 2
Nagaraj Tadipatri
"Nagaraj" wrote:
> Hi,
> try
> catch (Exception e)
> I am getting error.
> StackTrace at
> Thanks in advance.
> > Nagaraj Tadipatri
A Not able to load an add-in for outlook 2007 developed in VSTO 2005 Outlook VBA and Custom Forms 2
M Will a VSTO C# Outlook 2007 Add-in work on Outlook 2010? Outlook VBA and Custom Forms 1
O Third-party VSTO 2005 SE plug-in for Outlook 2007: what should I signwith a publisher certificate? Outlook VBA and Custom Forms 3
M c# vsto Outlook.ApplicationEvents_11_NewMailEx Outlook VBA and Custom Forms 1
O VSTO - Outlook Add-In - Get GAL data Outlook VBA and Custom Forms 1
K Outlook VSTO Add-in not visible in Trust Center after installing Outlook VBA and Custom Forms 1
X Highlight block of text in an outlook mail using c#2008 vsto Outlook VBA and Custom Forms 1
W My VSTO 3.0 Outlook addin doesn’t load Outlook VBA and Custom Forms 1
O Outlook VSTO 2005 plug-in installer: CLSID = ? Outlook VBA and Custom Forms 3
E Opening WinForm in Outlook 2003 VSTO Addin with Wordmail enabled Outlook VBA and Custom Forms 1
M Develop for OL2003 on OL2007 machine using VS2008 and VSTO? Outlook VBA and Custom Forms 1
E VSTO 2008 how to bind Form Region controls to Item data fields Outlook VBA and Custom Forms 2
E VSTO 2008 how to bind Form Region controls to Item data fields Outlook VBA and Custom Forms 3
M VSTO deployment? Outlook VBA and Custom Forms 1
M VSTO C#: How do I declare an application scope variable? Outlook VBA and Custom Forms 2
S VSTO calling unmanged function Outlook VBA and Custom Forms 3
G Interop or VSTO or ? Outlook VBA and Custom Forms 2
M VSTO 2007 Addin auto-disabled on one machine but not another on installation? Outlook VBA and Custom Forms 1
O using VSTO to get Available Mailboxes Outlook VBA and Custom Forms 11
M VSTO Outlook2007 Addin. After switching from 3.5 to 2.0 Framework i get "'MSB3185: EntryPoint not sp Outlook VBA and Custom Forms 1
C Problem installing VSTO AddIn on Vista Outlook VBA and Custom Forms 3
V Outlook created new profile? Using Outlook 1
J Outlook inbox question Using Outlook 3
M Anyone integrated AI website builders with Outlook for automated client communications? Using Outlook 1
V Gmail in Outlook Using Outlook 2
T Where has the Copilot icon gone in my Outlook desktop client? Using Outlook 5
P New way by Microsoft to get people to use the new Outlook Using Outlook 4
T Constantly Have To Log In To Outlook On The Web Using Outlook.com accounts in Outlook 2
O Outlook 2024 not showing that messages are replied to or forwarded Using Outlook 3
C I don't understand Outlook or Microsoft, anymore Using Outlook 12
P My Feedback to Microsoft and their response; also New Outlook roadmap Using Outlook 0
