Script to send with custom form
  • Thread starter Thread starter Paul
P
Paul
I'm using outlook 2003.
I've created an custom form that I would like to use. And I've got a question;
Is it possible that when I send to form, the recieveing end triggers a code
or script when opening or reading the e-mail? If so, how would I set this up?
Cheers,
Paul
That's possible only within your own organization, and only if you can
publish to the Organizational Forms library on the server. See
http://www.outlookcode.com/article.aspx?id=61
Sue Mosher
"Paul" <Paul> wrote in message
news:5AC1A8AF-E621-4732-B92C-99C7AD350BED@microsoft.com...
> Hi,
> question;
> code
> up?
> Cheers,
> Paul
Sue,
What I would like to accomplish is that when the receipent reads or opens
the e-mail I send him it automatically runs a code that will publish a .oft,
that is located in a map in our shared network drive, into their personal
folders library.
I can't publish in the organizational library.
Is this possible? And can you help me with the code to accomplish this?
Cheers,
Paul
> > Sue Mosher
> > Hi,
> > question;
> > code
> > up?
> > Cheers,
> > Paul
Did you look at the page I suggested? It explains that if you can't publish
to Org Forms, the ony way to get a form to run code is to publish to each
user's Personal Forms library. How likely is that?
Sue Mosher
news:D9431D6F-CC75-4B51-AB83-707DCBF81822@microsoft.com...
> Sue,
> .oft,
> folders library.
> Cheers,
> Paul
> > > Hi,
> > > question;
> > > code
> > > this
> > > up?
> >> > Cheers,
> >> > Paul
In article <D9431D6F-CC75-4B51-AB83-707DCBF81822@microsoft.com>,
Give the form to your IT department and let them publish it.
Hollis Paul
Mukilteo, WA USA
H Customizing "Send to" Attachment Script Outlook VBA and Custom Forms 5
G Script in rule to send to multiple emails found in message bo Outlook VBA and Custom Forms 11
V "Accept + Send the Response now", VBA script? Using Outlook 1
S Script to use in a rule when a message arrives to send to email in the message Outlook VBA and Custom Forms 12
S Works individually with MFCMAPI but not bulk with VBA script... Outlook VBA and Custom Forms 2
R Script for simplifying spam control Outlook VBA and Custom Forms 7
