AdvancedSearchComplete Search param not immediately ready for use
  • Thread starter Thread starter sb
sb
I am developing an Outlook add-in using VSTO in VS2008, using .Net 2.0 and
Outlook 2003. I have a bit of functionality that executes an advancedsearch
and catches the AdvancedSearchComplete event. However, when the results come
back, the Search parameter passed to the event handler does not appear to be
ready for use.
The search:
sFilter = "\"urn:schemas:httpmail:subject\" LIKE '%subject
string%' AND ";
sFilter += "\"urn:schemas:httpmail:textdescription\" LIKE '%text
description%'";
//Execute the search
try
Outlook.Application a = m_addIn.Application;
sScope = "'\\\\valid folder\\'";
a.AdvancedSearch(sScope, sFilter, true, "Tag");
The event handler:
private void m_outlook_AdvancedSearchComplete(Outlook.Search
searchObj)
//MessageBox.Show(searchObj.Results.Count.ToString());
for (int i = 1; i <= searchObj.Results.Count; i++)
//do stuff
Everything seems to be working fine, the search is successful and the
AdvancedSearchComplete event fires when it is done. However, when
AdvancedSearchComplete is fired as expected, searchObj.Results.Count is
ALWAYS zero. But... If that MessageBox.Show line is uncommented, it always
displays '0', but then the subsequent calls to searchObj in the for... and
beyond correctly reflect the search Results. I have tried a Thread.Sleep()
call in there to no avail.
Thoughts? I thought the results were guaranteed to be ready when this event
fires. Is there some setting I am missing somewhere?
thanks
I can't repro that here using VS 2008, C# and Outlook 2003. I used this
search as a test:
Outlook.Search search = _outlook.AdvancedSearch("Inbox",
"urn:schemas:mailheader:subject = 'Checking in'", true, "Foo");
When the event fired the MessageBox showed 1 result in my Inbox, as
expected.
If you want to loop the Results collection you will need to use
GetFirst()/GetLast() or get an IEnumerator object to iterate the collection
that way.
"sb" <sb> wrote in message
news:AD2A8C67-09BE-41FA-9014-EDABFE24CB4D@microsoft.com...
> Hello,
> advancedsearch
> come
> be
> ready for use.
> The search:
> string%' AND ";
> '%text
> description%'";
> try
> The event handler:
> searchObj)
> //do stuff
> always
> Thread.Sleep()
> event
> thanks
Re: AdvancedSearchComplete Search param not immediately ready for
Thank you for your response, Ken.
It seems strange it only happens for me. Are you using .Net 2.0 (as opposed
to the VS2008 default of 3.5)? Also, I am running on Win 7 RC, and the email
accounts in my test config of Outlook are just a couple of hotmail addresses
using Outlook Connector. Not sure why any of these would make any difference.
In any event, I finally just solved this problem with an
Application.DoEvents() call in the event handler. Weird.
Forgive me, I am no Outlook extensibility master. While
GetFirst()/GetNext() may be better in some way, why would a for() loop not
work to iterate the results?
thanks
> search as a test:
> expected.
> that way.
> > Hello,
> > advancedsearch
> > come
> > be
> > ready for use.
> > The search:
> > string%' AND ";
> > '%text
> > description%'";
> > try
> > The event handler:
> > searchObj)
> > //do stuff
> > always
> > Thread.Sleep()
> > event
> > thanks
I did the test in an addin I'm working on which happens to use Framework 2.0
and not 3.5. The code was tested on WinXP SP3 and Outlook 2003 SP3.
I'd guess that the connector and hotmail wouldn't make a difference, the
search is being done on a specific folder or folders. I don't use the
connector, are the folders you were searching local in a PST file? If so
then there shouldn't be a difference. I happened to test using a cached
Exchange mailbox.
I wonder if using Application.AdvancedSearch() as a function, as I did might
make a difference. You might try that and see.
I suggested using the Get* functions rather than something like
searchObject just because you don't have to deal with Outlook collections
starting with Item[1] and not Item[0]. One less thing to remember. Not a big
deal, I often use a for loop like yours.
news:170CA22D-495B-4399-ADE6-24A696A0E7E5@microsoft.com...
> opposed
> email
> addresses
> difference.
> thanks
Ah yes - I already encountered and passed that annoyance. <g
Thanks again for your help.
C Search bar moved on its own? Using Outlook 4
A Search People>press enter box disappears. Using Outlook 3
efire9207 Addressbook Search Using Outlook 4
Victor_50 Outlook 365 Quick search by period (today, yesterday, last week) completely missing in newest OL 365 Using Outlook 0
A 'search people' now asks me to 'press enter' Using Outlook 11
A Relocate Search Bar in Outlook Using Outlook 2
T Outlook365 search item listed as "potential matches" can't be opened Using Outlook 0
P Outlook 2013 search no longer works Using Outlook 2
C How to search for items in Outbox with multiple accounts? Using Outlook 20
J search doesn't find anything Using Outlook 1
C Search not accurate, but not indexing Using Outlook 9
H Outlook 2019 intermittent search results Using Outlook 0
H Search Email Header for Content Type Outlook VBA and Custom Forms 1
P Posts in Folder No Longer Group by Conversation Column After Search Using Outlook 0
O Advanced search - can I use booleans Using Outlook 3
M Something went wrong and your search couldn't be completed Using Outlook 1
L New Location for the Search Bar Using Outlook 6
King Mustard Sort search groups by amount of items? Using Outlook 1
