Is there an Outlook consultant in Denver, CO? Need VB customizati
  • Thread starter Thread starter Jeff
Jeff
As an advanced user, I need some help with forms design, some VB code to fix
bad phone number formatting and to help other users install custom forms. I
definitely need someone local to help with training and implementation.
jbro999@gmail.com
Jeff
You might want to send a message to outlook-dev-hire at yahoogroups.com with
details of your requirements, including the Outlook version(s) to be
supported. Once the moderator approves your message, Outlook developers on
the outlook-dev-hire list can respond directly to you if they're interested
in your project.
Sue Mosher
"Jeff" <Jeff> wrote in message
news:CAB885C2-A1B1-429C-A9DF-DF12618E6D16@microsoft.com...
> fix
> I
> jbro999@gmail.com
> > Jeff
S Same POP account on Outlook 2024 and Outlook Classic ? Using Outlook 17
P Preventing permanent deletions in Outlook on the Web Using Outlook 0
L any trick to embedding images in new outlook and outlook on the web contacts? Using Outlook 4
L new outlook contacts searching Using Outlook 5
W New Outlook PEOPLE blank Using Outlook 6
C New Outlook issues with Gmail, particularly labels/folders Using Outlook 4
V Outlook created new profile? Using Outlook 1
J Outlook inbox question Using Outlook 4
