Failed to create an RDO session instance: Class not registered
  • Thread starter Thread starter Suzette
Suzette
I uninstalled a virus software and starting getting this error in Outlook. I
have completed the following steps trying to get this problem corrected.
1. Open Outlook in Safe Mode and enabled and disabled on Add-In's
2. Defrag drive
3. Run Check Disk
4. Removed all entries in registry having to do with old virus software
5. Purchased and ran a registry cleaner
6. Uninstalled and reinstalled Outlook
I have run out of things to try. Anyone have in suggestions?
Did you re-register redemption.dll with regsvr32.exe?
What is the exact error?
Where does your code run (standalone exe, COM add-in, etc)?
Dmitry Streblechenko (MVP)
"Suzette" <Suzette> wrote in message
news:DBD451C0-778E-409F-A3D1-5EF85A9BB1C5@microsoft.com...
> I
> 2. Defrag drive
> 3. Run Check Disk
V Outlook Error The Attempted operation Failed. An Object Could Not be found Outlook VBA and Custom Forms 0
P Mail delivery failed returning message to sender Using Outlook 1
F 'General failure (URL) Server execution failed' Using Outlook 1
J An attempt operation failed. An object could not be found at line5. Outlook VBA and Custom Forms 2
H Outlook 2010, "The Operation Failed" Sending emails Using Outlook 4
J New Outlook 2007 form - try to send and get error Operation Failed Outlook VBA and Custom Forms 11
wallisellener database creation failed BCM (Business Contact Manager) 0
S Outlook 2013. Adding office 365 email account causes 'The operation failed' Using Outlook 2
R catalog Content Index failed-Unable to mount database.(hr=0x80004005,ec=-501) Exchange Server Administration 0
M Outlook 2010 Calendar error Operation Failed Using Outlook 6
J Synchronization of some deletions failed [0-130] Exchange Server Administration 6
M Synchronization of some deletions failed [0-130] Using Outlook 3
S Unknown error and The operation failed Using Outlook 1
S The operation failed error while send email to other domain. Using Outlook 1
R "The Operation Failed. The messaging interfaces have returned an unknown error Exchange Server Administration 3
P Sync Center appointments failed to synchronize Using Outlook 1
B Task List in To-Do Bar 'The operation failed. An object could not be found' Using Outlook 3
S COM Addin Failed to load in Outlook 2003 Outlook VBA and Custom Forms 1
S Failed to install Business Conctact Manager 2007 BCM (Business Contact Manager) 1
R RE: Business Contact manager failed to install BCM (Business Contact Manager) 1
A Creating Redemption.MAPIUtils failed with Windows 7 x64 Outlook VBA and Custom Forms 5
R SQL Server Setup failed - Please help?! BCM (Business Contact Manager) 2
M Cannot Send - "Operation failed. An object cannot be found" BCM (Business Contact Manager) 4
H Failed install BCM (Business Contact Manager) 2
D Outlook 2007: "the Operation Failed" on Send to Multiple addresses Using Outlook 6
L Exchange Management Console - Initializtion failed on Logon Failure: unknown username or bad passwor Exchange Server Administration 4
P Setup failed to install Business Contact Manager for Outlook 2007 BCM (Business Contact Manager) 2
E Re:BCM failed to install in outlook 2007 due to SQL Server Express 20 BCM (Business Contact Manager) 1
J The operation failed. Outlook VBA and Custom Forms 17
W Save Operation Failed error Outlook VBA and Custom Forms 7
T Re: Setup failed to install Business Contact Manager BCM (Business Contact Manager) 1
B Re: BCM failed to initialize the common language runtime BCM (Business Contact Manager) 4
E Connecting to database failed BCM (Business Contact Manager) 3
T Create a group from a large To distribution list Using Outlook 3
