Act to Outlook
  • Thread starter Thread starter Lanse
Act! 10 is Act! 2008 and BCM 2007, even with latest SP only supports direct
import of up to Act! 2007.
BCM 2010 beta claims that it will import versions of Act! up to v2009, but
in our testing, we found limited success. Don't know if it is simply a beta
issue or signs of a larger issue.
If you only want to get Contact fields, you could try exporting the Act!
contact data to a CSV file and then importing that way. You will lose your
calendar, notes, history, etc.
Keep in mind that BCM is not nearly as robust and simple to use as Act!, but
if you have very basic needs, it might fit the bill.
M Scott Schaffernoth
www.winnovative.com
Twitter: @insideSMBCRM
"Lanse" wrote:
> How can I transfer my ACT 10 contacts to Busines Contact Manager?
K ACT!/OUTLOOK BCM CONVERSION BCM (Business Contact Manager) 2
M Importing Contacts from Act 6.0 to Outlook 2007 BCM (Business Contact Manager) 3
J importing contacts, data, emails and attached files from ACT 2009 BCM (Business Contact Manager) 1
C mport ACT! 6.0 to BCM BCM (Business Contact Manager) 2
T RE: ACT to BCM Data Conversion BCM (Business Contact Manager) 1
A ACT! 10.0 to BCM 2007 BCM (Business Contact Manager) 2
L new outlook contacts searching Using Outlook 2
W New Outlook PEOPLE blank Using Outlook 7
C New Outlook issues with Gmail, particularly labels/folders Using Outlook 4
V Outlook created new profile? Using Outlook 1
J Outlook inbox question Using Outlook 4
M Anyone integrated AI website builders with Outlook for automated client communications? Using Outlook 1
V Gmail in Outlook Using Outlook 2
T Where has the Copilot icon gone in my Outlook desktop client? Using Outlook 6
P New way by Microsoft to get people to use the new Outlook Using Outlook 4
T Constantly Have To Log In To Outlook On The Web Using Outlook.com accounts in Outlook 2
O Outlook 2024 not showing that messages are replied to or forwarded Using Outlook 3
C I don't understand Outlook or Microsoft, anymore Using Outlook 12
P My Feedback to Microsoft and their response; also New Outlook roadmap Using Outlook 0
L Android Outlook Doesn't Update PC Notification Changes Using Outlook 0
D.Moore Outlook desktop client suggested searches question Using Outlook 22
Y Outlook 2016 (64-bit) Copy Local Cal. Events to Another Cal. with Modified Reminder time Using Outlook 2
D Cannot logon to Outlook.com, or outlook on Mac, outlook not updating on ipad, iphone Using Outlook 1
J unable to get my new install of Outlook to display mailboxes in the single-line format. Using Outlook 1
D Legacy Microsoft Outlook for Mac Support will end in Oct 2025 Using Outlook 8
C Nasty Bug Lurking In Outlook For Years. The Trigger. Any Fix Or Workaround? Using Outlook 12
