Outlook Macro to do a send/receive on specific group
  • Thread starter Thread starter Q2Ft
Q
Q2Ft
I have multiple email accounts setup in Outlook XP and want to split them
into groups. I want to have buttons assigned for each group that will run a
Macro to undertake a send/receive on that particular group only. I would be
grateful for any sample code to assist.
For that use the NameSpace.SyncObjects collection and get the desired
SyncObject, which is one of your send/receive groups, then call Start() on
that SyncObject. Each SyncObject has a Name property that can be used to
identify it. Where there's only one send/receive group for example, that
Name would be "All Accounts" (the default send/receive group).
"Cam" <Cam> wrote in message
news:3AE7E647-B04C-462D-ADEF-407DC883FD33@microsoft.com...
> a
> be
> Thanks.
B Looking for Outlook 2013 update for Send Drafts Macro Using Outlook 4
Witzker Macro to move @domain.xx of a Spammail to Blacklist in Outlook 2019 Outlook VBA and Custom Forms 7
C Outlook Subject Line Macro Outlook VBA and Custom Forms 0
P Macro to attach a file in a shared Outlook draft folder Outlook VBA and Custom Forms 2
R Macro to check file name with outlook address book Outlook VBA and Custom Forms 0
W macro to export outlook emails to excel Outlook VBA and Custom Forms 6
J Outlook Macro to Update Sharepoint Excel File Using Outlook 1
L Outlook 2007 - Macro Re Search Using Outlook 16
L Outlook 2007 Macro to Contact From a Field Using Outlook 3
A newb outlook macro help Outlook VBA and Custom Forms 1
Diane Poremsky Macro to Bulk Import Contacts and vCards into Outlook Using Outlook 0
S Outlook 7 VBA macro for multiple filing Outlook VBA and Custom Forms 1
S Macro in an excel for outlook. Outlook VBA and Custom Forms 2
A Outlook Macro Causing Excel Error Outlook VBA and Custom Forms 0
S Outlook Macro Reply to a message Outlook VBA and Custom Forms 1
Diane Poremsky Macro to Bulk Import vCards into Outlook Using Outlook 0
