Chaning MessageClass with Preview Pane
  • Thread starter Thread starter ZG1qYW1lcw
Z
ZG1qYW1lcw
I'm trying to change MessageClass when an item is opened so as to open a
custom form. My code works fine when the Preview Pane is closed; it doesn't
work when the pane is open. I've tried changing the form, clearing forms
cache, etc.; I'm sure it's not a form problem. I've tested and tried it many
times -- the behavior is that it works when Preview Pane is closed, and opens
the default IPM.Note when the Preview Pane is open. (If anyone is curious,
my ultimate goal is to provide a preview tab where all text in the message is
changed to an easy-to-read font, but not change the message permanently.)
Here's my code:
'CONNECTION CODE
Option Explicit
Dim WithEvents objInsps As Outlook.Inspectors
Private Sub AddinInstance_OnConnection(ByVal Application As Object, ByVal
ConnectMode As AddInDesignerObjects.ext_ConnectMode, ByVal AddInInst As
Object, custom() As Variant)
Set objInsps = Application.Inspectors
AddInInst.object = Me
Private Sub AddinInstance_OnDisconnection(ByVal RemoveMode As
AddInDesignerObjects.ext_DisconnectMode, custom() As Variant)
Set objInsps = Nothing
Private Sub objInsps_NewInspector(ByVal currInsp As Inspector)
Dim ci As New clsInspectors
If currInsp.CurrentItem.Class = olMail Then
If currInsp.CurrentItem.MessageClass = "IPM.Note" Or
currInsp.CurrentItem.MessageClass = "IPM.Note.Preview" Then
If currInsp.CurrentItem.EntryID <> vbNullString Then 'Sent
Set ci = InspColl.Add(currInsp,
currInsp.CurrentItem.entryid) 'collection of clsInspectors
ci.IID = currInsp.CurrentItem.EntryID
ci.FirstActivation = True
'CLSINSPECTORS
Option Explicit
Public WithEvents currInsp As Inspector
Public IID As String
Public FirstActivation As Boolean
Private Sub currInsp_Activate()
If FirstActivation Then
currInsp.CurrentItem.Save
'The custom form contains a preview control on a tab called Preview,
which I populate here
'If the preview pane of the explorer from which I opened the item is
visible, currInsp.ModifiedFormPages("Preview") returns Nothing
FirstActivation = False
Private Sub currInsp_Close()
InspColl.Remove IID
Dave James
Forgot to mention, OL2003 SP3.
> Here's my code:
> 'CONNECTION CODE
> Option Explicit
> End Sub
> End Sub
> End If
> End If
> End If
> End Sub
> 'CLSINSPECTORS
> Option Explicit
> End If
> End Sub
> InspColl.Remove IID
> End Sub
> Thanks,
> Dave James
NewInspector() won't help you at all for the preview pane, that's for items
that are being opened, not previewed. You need to handle
Explorer.SelectionChange() for the ActiveExplorer to know what is now
selected and in the preview pane. You would work with the Selection
collection.
Previewing custom forms in the preview pane won't work though, they are
blocked from previewing. You could change the MessageClass and save the item
to preserve the change, but for a custom form you'd just end up with the
preview pane showing the "can't show this message" warning.
"dmjames" <dmjames> wrote in message
news:37FEE281-4404-42C5-8CC1-2433F88521AF@microsoft.com...
> > doesn't
> > many
> > opens
> > curious,
> > message is
>> Here's my code:
>> 'CONNECTION CODE
>> Option Explicit
> > End Sub
> > End Sub
> > End If
> > End If
> > End If
> > End Sub
>> 'CLSINSPECTORS
>> Option Explicit
> > Preview,
> > is
> > End If
> > End Sub
> > InspColl.Remove IID
> > End Sub
>> Thanks,
>> Dave James
Thanks for the info, but maybe I wasn't completely clear. What I want to do
is change MessageClass when an item is opened and change it back when it's
closed. I don't care about the Preview Pane, except that when it's open it
appears to "lock" the item in some way and prevent the custom form from being
used. If I close the Preview Pane my code works as expected, but it should
work whether or not the Preview Pane is open.
Given this, is trapping SelectionChange() still the answer or is there
another way to "unlock" the item being opened?
Thanks again,
Dave James
> collection.
> >> doesn't
> >> many
> >> opens
> >> curious,
> >> message is
> >> Here's my code:
> >> 'CONNECTION CODE
> >> Option Explicit
> >> End Sub
> >> End Sub
> >> End If
> >> End If
> >> End If
> >> End Sub
> >> 'CLSINSPECTORS
> >> Option Explicit
> >> Preview,
> >> is
> >> End If
> >> End Sub
> >> InspColl.Remove IID
> >> End Sub
> >> Thanks,
> >> Dave James
I don't know about the item being locked, I've never run into that. But
SelectionChange() is still the only way to know when a selection is changed
and to what.
news:B4575B01-3BC8-4AAE-AC2D-85460CC8FAA5@microsoft.com...
> do
> it
> being
> should
> Thanks again,
> Dave James
L Applying new form to existing contacts -- MessageClass Outlook VBA and Custom Forms 3
M How to automatically refresh an appointment windows after changing the MessageClass property ? Outlook VBA and Custom Forms 4
D.Moore Preview pane question Outlook VBA and Custom Forms 3
HarvMan January Windows 10 preview update force installs new Outlook Using Outlook 1
D Amazon and some other emails not showing in Preview Pane Using Outlook 10
P Categorise emails on sending - macro not working in Preview mode Using Outlook 1
T Outlook 2016 mp3 attach "this file cannot be preview because there is no previewer installed for it" Using Outlook 1
H What Controls what is shown in the preview pane Outlook VBA and Custom Forms 1
A OL16 C2R attachment preview fails Using Outlook 8
Z Importing PST files from Outlook 07 to Outlook mac Preview Using Outlook 1
I Outlook 2016 Preview Address Book Options Using Outlook 2
Diane Poremsky Outlook 2016 Preview Using Outlook 4
Diane Poremsky Disable Live Preview in Outlook and Word Using Outlook 0
Diane Poremsky New Office365 Feature: URL Preview in OWA Using Outlook 0
J Copy email from preview pane with headers Outlook VBA and Custom Forms 4
1Firefly Outlook 2013 Converstation preview does not show my last reply Exchange Server Administration 1
L Sort bar at top of inbox preview outlook 2013 Using Outlook 1
Y (Shared Folder) Using the preview pane to open and close a fax, without opening the email itself Using Outlook 1
A Possible to modify people preview window? Using Outlook 1
B Outlook 2010 won't preview Office attachments Using Outlook 3
D Use Outlook 2003 embedded imaged cannot print from the mail preview list Using Outlook 4
M Estimated time in preview bar. Using Outlook 1
K Outlook 2007 preview jpg files Using Outlook 5
M How to get the preview pane handle, when it is created with menu c Outlook VBA and Custom Forms 1
E Preview of Form Region Outlook VBA and Custom Forms 4
